SSH RSA Key Question
Dean Romanelli
Level 8
Level 8
So part of my standard rollout is to create an SSH key in each 2960 I deploy - crypto key generate rsa modulus 2048.
After I do this and check it with show crypto key mypubkey rsa, I see the 2048 key I created, but there is also a 512 and a 768 key under the mypubkey output as well. Even if I zeroize the key then recreate it, a 768 key reappears along with the 2048 key.
Why is that, and how can I be sure the 2048 key will be used when someone SSH's to the device and not the 512 or 768 key?
The default key will show up and also be regenerated when a crypto function is used without a dedicated key (but I've seen platform dependent differences). Just make sure that you always reference your own key. Here is a guide how to do that:
https://community.cisco.com/t5/security-documents/guide-to-better-ssh-security/ta-p/3133344
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Karsten,
Let me ask you this: If I zeroize all rsa keys, then create a new 2048 bit rsa key as below:
crypto key zeroize rsa
crypto key gen rsa mod 2048 label dundermifflin
ip ssh rsa keypair-name dundermifflin
When I show crypto key mypubkey rsa, I see the 2048 key as "dundermifflin," and then I see a new auto generated 768 key ("temp key") as "dundermifflin.server."  You're saying as long as I reference "dundermifflin" and not "dundermifflin.server" in the ip ssh rsa keypair command, I can be sure the 2048 key will always be used when SSH'd to?
