ssh source interface
steffenplorin
Community Member
I do a ssh session to a remote catalyst. Now I want open another ssh session from that device to a neigbhor 192.168.1.27
I configure on the ssh device 192.168.1.1 as secondary on a vlan 5 interface I can ping 192.168.1.27 with advanced ping from source 192.168.1.1
What will be happens if I configure ip ssh source-interface vlan 5, do I lost my actual ssh session immediately ????
Or is this the way to get hop-by-hop access to 192.168.1.27 Please remind the first step is that I come via ssh from 10.51.1.x
Any answer appreciated
The command "ip ssh source-interface" controls the sessions that are initiated *from* your switch/router. They don't change how you ssh to that device. That is still controlled by access-lists/access-classes.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
thx,
important to me is from that device. ssh from 10.x.x.x in that device is ok, then from that device I'll jump ssh 192.168.1.x via specific interface vlan 5
When I conf i ip ssh source-interface vlan 5, do I lost my ssh connection via 10.x.x.x or not ?
no, your actual ssh-session should not be affected.
great thx
