SSHv2 on Cisco Switches and Routers
cisco
1)    SSHv2 is supported on all Switches and Routers ?
2)  Is it related to hardware or software ? as i cant see in data sheets
3)  If its related to Software which IOS shall i go for ?
regards
Neo
glen.grant
  Its code version dependant .
If you are looking for specific features, you should check out the Feature Navigator.  You can tell it what you have and what features you're looking for and usually can give you an image that best suits your requirement.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Please rate helpful posts.
SSH is supported on the routers and switches.
for which ever version that you will be wanting to use make sure the image name has K9 in it. Then you will have SSH available to you, just make sure if you are upgrading devices you have SmartNet support.
