Stable iOS for 3650
Wingnut2015
Hello all,
Curious to know which is the best (subjective, I know) iOS version I should run on a 3650 WLC?
sh run indicates I am running version 16.3 and I want to do some updates.
Thank you
Cheers,
Leo Laohoo
If you want to run WLC on the 3650 then you stay with 16.3.X because any version after 16.3.X do not support CA.
check the link below.  16.9.4 is the recommended release, but it requires smart licensing. "If you are not prepared for smart licensing, then 16.6.7 is the recommended version for Catalyst 3850 and 3650 Switches."
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/214814-recommended-releases-for-catalyst-9200-9.html
Muhammad Awais Khan
Leo Laohoo
