02-04-2012 12:14 AM - edited 03-07-2019 04:43 AM
Dear all,
can i stack cisco (ws-c3750G-12s) with (ws-c3750X-24p-poe-s) with (ws-c3750-48p-10/100 poe)
i mean even a switch is 10/100 and the other switch is 10/100/1000?
thanks
Ahmed Taha
Solved! Go to Solution.
02-04-2012 12:20 AM
Sure you can.
Make sure you have the same IOS version and have the same feature set.
02-04-2012 12:33 AM
Yes you can.
Cisco Catalyst 3750-X switches
• Investment protection with backward compatibility with all other models of Cisco Catalyst 3750 Series Switches*
* The 3750-X Fiber switches (WS-C3750X-12S and WS-C3750X-24S) don't stack with the old WS-C3750G-12S switches due to HW and SW limitations on the WS-C3750G-12S.
So you're fine using WS-C3750G-12S.
HTH,
Toshi
02-04-2012 06:25 AM
Yes you can do that as long as they have. The same iOS
02-04-2012 12:20 AM
Sure you can.
02-04-2012 12:33 AM
Yes you can.
HTH,
Toshi
02-04-2012 06:25 AM
