02-04-2012 03:50 AM - edited 03-07-2019 04:43 AM
02-04-2012 04:35 AM
Hi Alan,
If it's a PC go to 'Config' tab and under 'Global Settings', you'll see a field for the 'Gateway.' Enter the IP address of the router’s LAN interface. Click the 'FastEthernet' tab on the left panel to set the host IP address and subnet mask.
Click the 'Desktop' tab, open a command or DOS prompt and type 'ipconfig' to verify.
Let me know if it's a router you're referring to. Enjoy labbing! 😉
02-04-2012 07:36 AM
02-04-2012 09:32 AM
I can't help you further without giving any info or posting your .pkt file of the network you're referring to. I would suggest you start reading this link:
http://learn-networking.com/network-design/configure-a-router-with-packet-tracer
