Stack Behavior on a Standalone Switch
ruyelpequenocid
Frequent Visitor
Frequent Visitor
The premise
A switch out of the box already shows "stack behaviors and messages".
As indicated correctly by Reza Sharifi and Martin L, this is common behavior on stackable models. Basically they are always "stack-ready"
Device Details
Switch Ports Model              SW Version        SW Image              Mode
*    1 41    C9300-24S          17.03.05          CAT9K_IOSXE           INSTALL
Switch#show switch
Switch/Stack Mac Address : aaaa.bbbb.cccc - Local Mac Address
Mac persistency wait time: Indefinite
                                             H/W   Current
Switch#   Role    Mac Address     Priority Version  State
*1       Active   aaaa.bbbb.cccc     1      V01     Ready
Behavior
At reload:
Switch#reload
Reload command is being issued on Active unit, this will reload the whole stack
Proceed with reload? [confirm]
During boot:
Both links down, not waiting for other switches
Switch number is 1
Showing an ever resilient/persistent "provision" statement in the running configuration?
NOTE: This "provision" line remains persistent throughout physical removal from a stack, wiping, power-cycling, etc.
Switch#show run | include provision
switch 1 provision c9300-24s
Attempting to remove the provision from the switch itself does not work.
Switch(config)#no switch 1 provision
 Error: A switch is already physically present at this location
Switch(config)#no switch 1 provision c9300-24s
Conclusion
Stackable models like 3850s, 9300s, etc. are stack-ready out of the box and display some of these stack behaviors, even if working as a standalone switch.
Reza Sharifi
If the port numbering starts with 1/0/1 then the switch, may already be in standalone mode. See page 8 in this link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-10/configuration_guide/stck_mgr_ha/b_1610_stck_mgr_ha_9300_cg.pdf
Martin L
I agree with Reza; all stack-capable switches are number 1 and have ports in form of 1/0/x numbering system by default;  they are sort of stack ready; if you want to add or change provision number but it is not necessary as long as your switches are not stack-wise connected.  reused switches could be 2/0/x or 3/0/x but working as standalone if they are not connected via stack cables.
Regards, ML
**Please Rate All Helpful Responses **
