stack cable.
jmp780718
Level 3
Level 3
Hi.
which is the maximum length of a cable stack?, I need some way to connect four switches which is at a distance of 7 meters between them.
Thank you.
Leo Laohoo
I think the longest, CAB-STACK-3M, is only 3 metres.
Leo Laohoo
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe Leo is correct, i.e. longest cable is 3m.
If the 7m is between individual units, you're out of luck connecting them as a stack.  If the 7m is between "top" and "bottom" unit, what might work for you is connecting 1 to 2 and 3, and 4 to 2 and 3.  You could also just connect 1<>2<>3<>4, they will work as a stack, but then you lose stack redundancy and half your stack's bandwidth.  Lastly, you might stack 1 and 2 and 3 and 4 and interconnect the two stacks using normal port cables, perhaps with Etherchannel, if you have "extra" ports.
