Stack issue on Cisco 3750
Igor Koval
Community Member
Hi team,
I have an issue with the stack basing on Cisco 3750 switches.
Today on one of them, something went wrong and all ports are down.
Could you please advise, what happened? In what direction I should work to find root cause?
thank you
You can use the renumber command:
example:
switch 5 renumber 6
switch 3 renumber 5
switch 6 renumber 5
Don't remember exactly, but you may have to reload the stack for the change to take effect.
Reza Sharifi
Separate that switch from the stack and test is individually. Look for crash files on the flash card. Also, if the product is under warranty, open a TAC ticket and have them take a look at the hardware and software..
I have found out what is the root cause.
In stack, I have 4 switches:
1. Member
2. Master
3. Member
4. Member
But right now I have next picture
1. Member - status "Ready"
2. Master - status "Ready"
3. Member - status "Provisioned"
4. Member - status "Ready"
5. Member - status "Ready"
I have checked MAC addresses, I have noticed, that member 3, became member 5.
For resolving this issue, I just need make member 5 member 3, but I don't know how to do it exactly.
My plan is:
- remove member 3.
- change number of the member 5 to member 3
Is it correct?
Thank you,
Igor
example:
switch 5 renumber 6
switch 3 renumber 5
switch 6 renumber 5
Thank you.
I have last question.
Is it correct to do next:
switch 3 renumber 6
reload whole stack
then
switch 5 renumber 3
reload whole stack
