Stack MS425 with LR?
gossewaar
Frequent Visitor
Frequent Visitor
Can the MS425 switch be stacked with 40G LR transceivers instead of stacking cables?
inderdeepsingh1
Level 11
Level 11
Flexible stacking is available on MS425 switches, which do not have dedicated stacking ports; any SFP+ interface on these switches can be configured as a stack port. You can use 2 x 10Gb/s (SFP+) or 2 x 40Gb/s (QSFP) interfaces can be connected together as flexible stacking ports. Have a look on the below document ad let me know if it answer your query ?
https://documentation.meraki.com/MS/Stacking/Switch_Stacks#Configuring_a_Flexible_Switch_Stack
Inderdeep Singh
www.thenetworkdna.com
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
CMR
Meraki Community All-Star
Theoretically yes, there is nothing special about the stacking cables, they are just normal DACs.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
inderdeepsingh1
Level 11
Level 11
Inderdeep Singh
Philip D'Ath
The following are listed as compatible:
MA-QSFP-40G-LR4 (single mode)
MA-QSFP-40G-CSR4 (multi mode)
MA-QSFP-40G-SR-BD (multi mode)
