Stack of 5 Switches reload command at once
 Hi Experts,
I would like to know if, lets say, we have 5 or 6 switches in a stack, but I want to reload all the devices at once, which command should I use?
I have seen the reload slot  [id] command, but the slot is referencing the switch device or something else?
For instance, Im currently in the master, which is the managed one, so if I simply enter the reload command, will this command reboot the entire stack members as well at once? or just the master one?
johnd2310
Level 8
Level 8
Yes, if you just issue the reload command from the master, the whole stack will reboot. The reload slot [id] will reload a single switch.
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
John
thank you so much for your answer and response.
