I am working with 2 3750X switches that are stacked via the normal stacking cables, this part is working normally. The Stack-Power is not working however. I have the cables connected Switch 1, Port 1 Green to Switch 2, Port 2 Yellow, and Switch 1, Port 2 Yellow to Switch 2, Port 1 Green. In a "Show Stack-Power Detail" I see the following. Here is also the config from a show run. I am running this in a lab to build it so I only have 1 power supply per switch connected (only have 2 of the special power cables). What am I missing to make this work?? I am trying to set it up in redundant non-strict mode.
Thank you,
John
Power Stack Stack Stack Total Rsvd Alloc Unused Num Num
Name Mode Topolgy Pwr(W) Pwr(W) Pwr(W) Pwr(W) SW PS
Powerstack-2 SP-PS Stndaln 715 42 223 450 1 1
Power stack name: Powerstack-2
Stack mode: Redundant
Stack topology: Standalone
Switch 2:
Power budget: 673
Power allocated: 223
Low port priority value: 22
High port priority value: 13
Switch priority value: 4
Port 1 status: Not connected
Port 2 status: Not connected
Neighbor on port 1: 0000.0000.0000
Neighbor on port 2: 0000.0000.0000
stack-power stack Powerstack-2
mode redundant
stack-power switch 1
stack Powerstack-2
stack-power switch 2
stack Powerstack-2
