stack power issues
Hi ,
stack of two WS-C3750X-48T-S switches poping below error continuously and its observed after going for upgrade to
c3750e-universalk9-mz.122-55.SE6.bin
not able to get whts making switch to throw these logs-
Feb 25 09:36:46: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
Feb 25 09:37:46: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
Feb 25 09:38:46: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
Feb 25 09:39:46: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
Feb 25 09:40:46: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
Feb 25 09:41:47: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
Feb 25 09:42:47: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
Feb 25 09:43:47: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
#show ev   nv power all
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     LIT145204QP  OK              Good     Good     350/0
1B  C3KX-PWR-350WAC     LIT145204TG  OK              Good     Good     350/0
2A  C3KX-PWR-350WAC     LIT145204S8  OK              Good     Good     350/0
2B  C3KX-PWR-350WAC     LIT145204RY  OK              Good     Good     350/0
9W-MUM-SIROYA-CORE-SW-1#show stack-power
Power stack name: Powerstack-1
    Stack mode: Power sharing
    Stack topology: Ring
    Switch 1:
        Power budget: 223
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1: 503d.e5c2.9680
        Neighbor on port 2: 503d.e5c2.9680
    Switch 2:
        Power budget: 206
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Neighbor on port 1: 503d.e585.fc00
        Neighbor on port 2: 503d.e585.fc00
Thanks for help
27 views no reply ?
any one using IOS - c3750e-universalk9-mz.122-55.SE6.bin ?
I suspect below bug but not sure about power budget 223W .
Hi Sagar,
Explanation: Switch # does not have sufficient power budget. There is not quite enough
input power in the power stack to ensure that every switch receives its 190W/223W/etc
MINPOWER "minimum" power budget. This means that StackPower cannot guarantee the
identified switch will not lose power or load-shed.
The problem could be fixed by either one of the following options:
Option 1: Put one or both of the switches into standalone with these
commands:
                 Switch(config)#stack-power switch 2
                  Switch(config-switch-stackpower)#standalone
Then wait 60 to 90 seconds and verify/check if the "UNDER_BUDGET" syslog
ceases occurring. If it does, then put the switch or switches back out of
standalone ("no standalone") and see if the syslog still stays away.  If it
does, then the problem is solved (permanently).
This should be a non service affecting option as you have the power stack
setup in power-sharing mode but i would suggest you to do it in a downtime
window.
Option 2: Power cycle the switch throwing this error message. Please note
that we must do a power cycle, not a reload as we do with IOS upgrade.
There's a difference in this particular case.
Inayath
*Plz rate the helpfull posts.
