stack-power stack name appears to have changed
Charlie Jones
I have a stack of 7 3750x switches connected via Stackwise (one logical switch).  Within this switch, I have created to powerstacks (4 switches in one, 3 in the second stack).  Here is my configuration:
stack-power switch 1
 stack Powerstack1
 standalone
stack-power switch 2
 stack Powerstack1
 standalone
stack-power switch 3
 stack Powerstack1
 standalone
stack-power switch 4
 stack Powerstack1
 standalone
stack-power switch 5
 stack Powerstack2
 standalone
stack-power switch 6
 stack Powerstack2
 standalone
stack-power switch 7
 stack Powerstack2
 standalone
When I issue the command "Show stack-power", it looks like the stack name has changed.  Before I noticed the stack name change, I noticed that all of the stack power ports were not enabled, so I went through and enabled all of them.  In fact, when I first noticed those ports were not enabled, the output for "show stack-power" had many entries for different Powerstack (see second chart).  Any suggestions on how to fix this?  I haven't rebooted the stack yet which I have a feeling will resolve it.
Power Stack           Stack   Stack    Total   Rsvd    Alloc   Unused  Num  Num
Name                  Mode    Topolgy  Pwr(W)  Pwr(W)  Pwr(W)  Pwr(W)  SW   PS
Powerstack2-5         SP-R    Ring     2860    770     916     1174    3    4
Powerstack1-3         SP-R    Ring     3575    772     999     1804    4    5
JAX-3750X-1501#sh stack-power
Powerstack1-1         SP-R    Stndaln  1430    760     272     398     1    2
Powerstack2           SP-R    Stndaln  715     45      239     431     1    1
Powerstack2-7         SP-R    Stndaln  1430    760     437     233     1    2
Powerstack2-5         SP-R    Stndaln  715     45      240     430     1    1
Powerstack1           SP-R    Stndaln  715     45      240     430     1    1
Powerstack1-2         SP-R    Stndaln  715     45      272     398     1    1
Powerstack1-3         SP-R    Stndaln  715     45      215     455     1    1
Reza Sharifi
Is the power stacking actually working?   Have you tested it?
The output of show stack-power should look like this:
Switch# show stack-power
Power stack name: Powerstack1
    Stack mode: Power sharing
    Switch 1:
        Power budget: 206
        Low port priority value: 17
        High port priority value: 16
        Switch priority value: 2
        Port A status: Not shut
        Port B status: Not shut
        Neighbor on port A: 0022.bdcf.ab00
        Neighbor on port B: 0022.bdd0.4380
    Switch 2:
        Power budget: 206
        Low port priority value: 12
        High port priority value: 11
        Switch priority value: 1
        Neighbor on port A: 0022.bdd0.6d00
        Neighbor on port B: 0022.bdcf.af80
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_53_se/configuration/guide/3750xscg/swstkpwr.html
