dell vrtx switch port channel to cisco fex 2248
Dragomir
i have a dell vrtx chassis built in 8 port switch that i have cabled 4 ports to a cisco fex tp.
on the 4 ports on the vrtx switch i have it like this
interface gigabitethernet0/1
shutdown
spanning-tree disable
channel-group 1 mode auto
interface gigabitethernet0/2
shutdown
interface gigabitethernet0/3
shutdown
interface gigabitethernet0/4
shutdown
how do i configure the cisco side of the port channel?
right now the port config is
interface Ethernet101/1/19
  switchport access vlan 50
  spanning-tree port-priority 128
  spanning-tree port type edge
  no shutdown
interface Ethernet101/1/21
interface Ethernet101/1/22
  no shutdown
interface Ethernet101/1/24
  no shutdown
the fex is connect via port channel o a nexus 7k
6 Replies 6
Reza Sharifi
Not familiar with Dell switches, but it appears that you are connecting a switch to a FEX.  FEX ports are designed to be connected to end devices such as servers, workstations, printers, etc.. and not to other switches.  So, I see two options.  1-Don't use the Dell switch and directly connect the servers to the FEX  2-Connect the Dell switch directly to the 7ks using VPC.
"The Cisco Nexus 2148T fabric extender does not support EtherChannels on its host interfaces. Therefore a maximum of two links can be configured in an EtherChannel from the server where each link is connected to a separate Fabric Extender. " (c)
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5500/sw/interfaces/6x/b_5500_Interfaces_Config_Guide_Release_602N12_chapter_0100.pdf
The other thing is STP. If you need to SPAN STP down through the Dell switch you can also create a L2 loop easily. So this should be very carefully considered.
I would vote for Reza's suggestion of connecting Dell switch directly to N7k.
Niko
HTH,
Niko
hi
do you mean that the fex 2148 will not support any etherchannels from other switches?
On host interfaces it does not.
Niko
HTH,
Niko
i heard you can connect a switch the the fex 2248 but need to use fex links. Is that true?
how do you configure this?
Dragomir
How do I configure the nexus 7k to attach the dell switch module to it? I don't want to cause a stp loop
