stack switch problem
wajid dabir
Level 3
Level 3
I have configured two cisco ws-c3750X switches in stack, stack is working fine but problem with the switch two is we are not reachable to network.
i can ping the gateway from the switch one,which is master but not able to ping from switch 2.
also i connect two laptop to individual switch and given the same subnet ip ,but also we are not able to ping each other.
Switch detail:
CORE_SWI#show switch
Switch/Stack Mac Address : 6c41.6aa5.de00
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 6c41.6aa5.de00     2      1       Ready
2       Member 442b.0310.1500     1      1       Ready
CORE_SWI#show swi
CORE_SWI#show switch de
CORE_SWI#show switch detail
                                           H/W   Current
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok         Ok                2        2
  2        Ok         Ok                1        1
CORE_SWI#
CORE_SWI#show ver
CORE_SWI#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTW
ARE (fc1)
CORE_SWI uptime is 21 weeks, 5 days, 14 hours, 1 minute
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5/c3750e-universalk9
-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-48 (PowerPC405) processor (revision A0) with 262144K bytes of me
mory.
Processor board ID FDO1717R1KM
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
104 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 6C:41:6A:A5:DE:00
Motherboard assembly number     : 73-12552-08
Motherboard serial number       : FDO171717T3
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-48T-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO17170W97
System serial number            : FDO1717R1KM
Top Assembly Part Number        : 800-31326-07
Top Assembly Revision Number    : B0
Version ID                      : V04
CLEI Code Number                : COMJT00ARD
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48       12.2(55)SE5           C3750E-UNIVERSALK9-M
     2 54    WS-C3750X-48       12.2(55)SE3           C3750E-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 1 day, 19 hours, 34 minutes
Base ethernet MAC Address       : 44:2B:03:10:15:00
Motherboard assembly number     : 73-12552-05
Motherboard serial number       : FDO16030NM2
Motherboard revision number     : C0
Daughterboard assembly number   : 800-32727-01
Daughterboard serial number     : FDO16030TKJ
System serial number            : FDO1603K2QE
Top assembly part number        : 800-31326-02
Top assembly revision number    : E0
Version ID                      : V02
CLEI Code Number                : COMJT00ARB
License Level                   : ipservices
License Type                    : Permanent
Next reboot licensing Level     : ipservices
Configuration register is 0xF
CORE_SWI#
CORE_SWI#show lice
CORE_SWI#show license all
CORE_SWI#show license all swi
CORE_SWI#show license all switch 1
License Store: Primary License Storage
StoreIndex: 0   Feature: ipbase                            Version: 1.0
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
License Store: Evaluation License Storage
StoreIndex: 0   Feature: ipservices                        Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Priority: None
CORE_SWI#show license all switch 2
StoreIndex: 1   Feature: ipservices                        Version: 1.0
        License State: Inactive
CORE_SWI#
Wajid Dabir
wajid dabir
Level 3
Level 3
what is a command to make license in use and to make other license not in use.
Wajid,
switch(config)#license boot level
switch(config)#end
switch(config)#do wr
switch(config)#do reload
Add on the beginning to not use a specific license.
If you want to change a license from switch 2:
switch#session 2
switch-2(config)#
Haihua
Haihua Rong
Level 5
Level 5
Hello Wajid,
Please send me the outputs from the next commands:
Sh run int x/x    -----------> for the affected device on switch 2
Sh ip int brief |  exc una
Sh vlan
Sh ip route
Who is the GW?
Verify the configuration for the device that it is connected on switch 2. Should be a problem with vlan assignment.
Haihua
My gateway is my firewall and i have only 1 vlan in network.
CORE_SWI#show ip int bri | exc una
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  192.168.1.201   YES manual up                    up
CORE_SWI#show vla
CORE_SWI#show vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5, Gi1/0/6
                                                Gi1/0/7, Gi1/0/8, Gi1/0/9
                                                Gi1/0/10, Gi1/0/11, Gi1/0/12
                                                Gi1/0/13, Gi1/0/14, Gi1/0/15
                                                Gi1/0/16, Gi1/0/17, Gi1/0/18
                                                Gi1/0/19, Gi1/0/20, Gi1/0/21
                                                Gi1/0/22, Gi1/0/23, Gi1/0/24
                                                Gi1/0/25, Gi1/0/26, Gi1/0/27
                                                Gi1/0/28, Gi1/0/29, Gi1/0/31
                                                Gi1/0/32, Gi1/0/33, Gi1/0/34
                                                Gi1/0/35, Gi1/0/36, Gi1/0/37
                                                Gi1/0/38, Gi1/0/39, Gi1/0/40
                                                Gi1/0/47, Gi1/0/48, Gi2/0/1
                                                Gi2/0/2, Gi2/0/3, Gi2/0/4
                                                Gi2/0/5, Gi2/0/6, Gi2/0/7
                                                Gi2/0/8, Gi2/0/9, Gi2/0/10
                                                Gi2/0/11, Gi2/0/12, Gi2/0/13
                                                Gi2/0/14, Gi2/0/15, Gi2/0/16
                                                Gi2/0/17, Gi2/0/18, Gi2/0/19
                                                Gi2/0/20, Gi2/0/21, Gi2/0/22
                                                Gi2/0/23, Gi2/0/24, Gi2/0/25
                                                Gi2/0/26, Gi2/0/27, Gi2/0/28
                                                Gi2/0/29, Gi2/0/31, Gi2/0/32
                                                Gi2/0/33, Gi2/0/34, Gi2/0/35
                                                Gi2/0/36, Gi2/0/37, Gi2/0/38
                                                Gi2/0/39, Gi2/0/40, Gi2/0/47
                                                Gi2/0/48
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
CORE_SWI#sho ip route
Default gateway is 192.168.1.5
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
