stackable switches
ozgurguler
Level 2
Level 2
Hello;
Are there any stackable switch of Cisco other than 3750 and 3750-E? Does 3560 or 3560-E support stacking? If there is any stackable switch other than 3750 and 3750-E, what are their stacking capacity?
Thanks to everyone..
griffijo
Level 5
Level 5
Good morning. The only current offering of stackable switches is the Catalyst 3750. No other switch supports stacking.
I have heard that there is going to be an upgrade of the 3750 from a 32Gbps backplane to a 64Gbps backplane. You will be able to mix a 32Gbps 3750 with a 64Gbps 3750, but you will only get 32Gbps on the backplane.
