Stacked 3750X output queue drop reason?
Zaaf Aba
Hi all
Please accept my apologies for posting so much command output and thanks in advance for your support.
- I am tring to find the reason for drops on the port connected to my colleague's pc but unfortunately haven't been able to conclude. I have googled and came across following commands used by others attempting to find the reason for drops.
- Secondly I understand that 3750x has four output queues named queue 0, queue 1, queue 2, queue 3 and the output of command "show mls qos interface Gi5/0/21 statistics" confirms that but why is command "remote command 5 sh platform port-asic stats drop Gi5/0/21" showing eight queues (Queue 0 to Queue 7). FYI the drop counters for output queue 1 matches in the output of both commands.
- Thirdly in the output of command
sh platform pm if-numbers relevant to 5/0/21
indicates that it is on ASIC 1 port25. I am not able to understand how is that a logical port with in 1 or what?
interface gid gpn lpn port slot unit slun port-type lpn-idb gpn-idb
Gi5/0/21 245 245 21 1/25 5 21 21 remote No Yes
and the output of command also shows that it is on ASIC 1 hw-i 25
sh platform pm platform-block
interface gid gpn lpn asic hw-i flags sp dp bundle vlan mvid mac so_di i_vlan
Gi5/0/21 245 245 21 1 25 R U 0 0 no 0 0 0 61685 0
and Lastly in the output of command
sh platform port-asic stats drop asic 1
relevant to port 25 the drop counters don't match up with the counters of other commands, Please explain why?
Switch_Stack#sh ver
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 15.0(2)SE8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 13-May-15 23:01 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
Switch_Stack uptime is 2 years, 3 weeks, 5 days, 16 hours, 30 minutes
System restarted at 00:06:10 BST Fri Aug 14 2015
System image file is "flash:/c3750e-ipbasek9-mz.150-2.SE8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
cisco WS-C3750X-48P (PowerPC405) processor (revision F0) with 262144K bytes of memory.
Processor board ID FDO1635X0KR
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
288 Gigabit Ethernet interfaces
12 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 6C:20:56:0B:DF:00
Motherboard assembly number : 73-1255?-??
Motherboard serial number : FDO16350???
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C3750X-48PF-L
Daughterboard assembly number : 800-3272?-??
Daughterboard serial number : FDO16350???
System serial number : FDO1635X???
Top Assembly Part Number : 800-31324-03
Top Assembly Revision Number : B0
Version ID : V03
CLEI Code Number : COMJZ00ARC
Hardware Board Revision Number : 0x04
Switch Ports Model SW Version SW Image
* 1 54 WS-C3750X-48P 15.0(2)SE8 C3750E-IPBASEK9-M
2 54 WS-C3750X-48P 15.0(2)SE8 C3750E-IPBASEK9-M
3 54 WS-C3750X-48P 15.0(2)SE8 C3750E-IPBASEK9-M
4 54 WS-C3750X-48P 15.0(2)SE8 C3750E-IPBASEK9-M
5 54 WS-C3750X-48P 15.0(2)SE8 C3750E-IPBASEK9-M
6 30 WS-C3750X-24P 15.0(2)SE8 C3750E-IPBASEK9-M
Switch 02
Switch Uptime : 2 years, 3 weeks, 5 days, 15 hours, 34 minutes
Base ethernet MAC Address : 60:73:5C:F1:BA:80
Motherboard assembly number : 73-12553-06
Motherboard serial number : FDO16320Q25
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO16342H8A
System serial number : FDO1632P0L8
Top assembly part number : 800-31324-03
Top assembly revision number : B0
Version ID : V03
License Level : lanbase
License Type : Permanent
Next reboot licensing Level : lanbase
Switch 03
Base ethernet MAC Address : 6C:20:56:04:36:80
Motherboard serial number : FDO16350U3N
Daughterboard serial number : FDO163509BQ
System serial number : FDO1635X0JY
Version ID : V03
Switch 04
Switch Uptime : 2 years, 3 weeks, 5 days, 15 hours, 33 minutes
Base ethernet MAC Address : 6C:20:56:04:4E:00
Motherboard serial number : FDO16350VW4
Daughterboard serial number : FDO163107AF
System serial number : FDO1635R1V5
Version ID : V03
Switch 05
Base ethernet MAC Address : 6C:20:56:05:16:80
Motherboard serial number : FDO163515G8
Daughterboard serial number : FDO16351K58
System serial number : FDO1635R2EB
Version ID : V03
Switch 06
Switch Uptime : 2 years, 3 weeks, 5 days, 15 hours, 35 minutes
Base ethernet MAC Address : B8:38:61:8D:78:00
Motherboard assembly number : 73-12551-10
Motherboard serial number : FDO17520Y4M
Model revision number : A0
Motherboard revision number : C0
Model number : WS-C3750X-24P-L
Daughterboard serial number : FDO17520JQS
System serial number : FDO1707P13W
Top assembly part number : 800-31325-08
Top assembly revision number : E0
Version ID : V05
CLEI Code Number : COMJR00ARE
Configuration register is 0xF
Switch_Stack#
Switch_Stack#sh inter Gi5/0/21
GigabitEthernet5/0/21 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 6c20.5605.1695 (bia 6c20.5605.1695)
Description: workstation
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 07:24:38, output 1y22w, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 99357
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 51000 bits/sec, 52 packets/sec
5 minute output rate 1154000 bits/sec, 101 packets/sec
4533830541 packets input, 3498078997568 bytes, 0 no buffer
Received 1764558 broadcasts (407346 multicasts)
0 watchdog, 407346 multicast, 0 pause input
4836403785 packets output, 5179566658240 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Switch_Stack# show mls qos interface Gi5/0/21 statistics
GigabitEthernet5/0/21 (All statistics are in packets)
dscp: incoming
0 - 4 : 309763192 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 0 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 3764911 0 0 0 24
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 23 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 0 0 3787620 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 238864826 0 0 0 0
5 - 7 : 0 0 0
cos: outgoing
0 - 4 : 498718714 0 0 0 23
5 - 7 : 0 3787617 38931978
output queues enqueued:
queue: threshold1 threshold2 threshold3
queue 0: 0 0 0
queue 1: 4091506655 293587113 38932434
queue 2: 0 0 0
queue 3: 23 0 594860694
output queues dropped:
queue 0: 0 0 0
queue 1: 99332 25 0
queue 2: 0 0 0
queue 3: 0 0 0
Policer: Inprofile: 0 OutofProfile: 0
Switch_Stack#remote command 5 sh platform port-asic stats drop Gi5/0/21
Switch : 5 :
Interface Gi5/0/21 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 99332
Weight 1 Frames 25
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Switch_Stack# sh platform pm if-numbers
Gi1/0/1 1 1 1 1/1 1 1 1 local Yes Yes
Gi1/0/2 2 2 2 1/0 1 2 2 local Yes Yes
Gi1/0/3 3 3 3 1/3 1 3 3 local Yes Yes
Gi1/0/4 4 4 4 1/2 1 4 4 local Yes Yes
Gi1/0/5 5 5 5 1/5 1 5 5 local Yes Yes
Gi1/0/6 6 6 6 1/4 1 6 6 local Yes Yes
Gi1/0/7 7 7 7 1/9 1 7 7 local Yes Yes
Gi1/0/8 8 8 8 1/8 1 8 8 local Yes Yes
Gi1/0/9 9 9 9 1/11 1 9 9 local Yes Yes
Gi1/0/10 10 10 10 1/10 1 10 10 local Yes Yes
Gi1/0/11 11 11 11 1/13 1 11 11 local Yes Yes
Gi1/0/12 12 12 12 1/12 1 12 12 local Yes Yes
Gi1/0/13 13 13 13 1/15 1 13 13 local Yes Yes
Gi1/0/14 14 14 14 1/14 1 14 14 local Yes Yes
Gi1/0/15 15 15 15 1/17 1 15 15 local Yes Yes
Gi1/0/16 16 16 16 1/16 1 16 16 local Yes Yes
Gi1/0/17 17 17 17 1/19 1 17 17 local Yes Yes
Gi1/0/18 18 18 18 1/18 1 18 18 local Yes Yes
Gi1/0/19 19 19 19 1/23 1 19 19 local Yes Yes
Gi1/0/20 20 20 20 1/22 1 20 20 local Yes Yes
Gi1/0/21 21 21 21 1/25 1 21 21 local Yes Yes
Gi1/0/22 22 22 22 1/24 1 22 22 local Yes Yes
Gi1/0/23 23 23 23 1/27 1 23 23 local Yes Yes
Gi1/0/24 24 24 24 1/26 1 24 24 local Yes Yes
Gi1/0/25 25 25 25 2/1 1 25 25 local Yes Yes
Gi1/0/26 26 26 26 2/0 1 26 26 local Yes Yes
Gi1/0/27 27 27 27 2/3 1 27 27 local Yes Yes
Gi1/0/28 28 28 28 2/2 1 28 28 local Yes Yes
Gi1/0/29 29 29 29 2/5 1 29 29 local Yes Yes
Gi1/0/30 30 30 30 2/4 1 30 30 local Yes Yes
Gi1/0/31 31 31 31 2/9 1 31 31 local Yes Yes
Gi1/0/32 32 32 32 2/8 1 32 32 local Yes Yes
Gi1/0/33 33 33 33 2/11 1 33 33 local Yes Yes
Gi1/0/34 34 34 34 2/10 1 34 34 local Yes Yes
Gi1/0/35 35 35 35 2/13 1 35 35 local Yes Yes
Gi1/0/36 36 36 36 2/12 1 36 36 local Yes Yes
Gi1/0/37 37 37 37 2/15 1 37 37 local Yes Yes
Gi1/0/38 38 38 38 2/14 1 38 38 local Yes Yes
Gi1/0/39 39 39 39 2/17 1 39 39 local Yes Yes
Gi1/0/40 40 40 40 2/16 1 40 40 local Yes Yes
Gi1/0/41 41 41 41 2/19 1 41 41 local Yes Yes
Gi1/0/42 42 42 42 2/18 1 42 42 local Yes Yes
Gi1/0/43 43 43 43 2/23 1 43 43 local Yes Yes
Gi1/0/44 44 44 44 2/22 1 44 44 local Yes Yes
Gi1/0/45 45 45 45 2/25 1 45 45 local Yes Yes
Gi1/0/46 46 46 46 2/24 1 46 46 local Yes Yes
Gi1/0/47 47 47 47 2/27 1 47 47 local Yes Yes
Gi1/0/48 48 48 48 2/26 1 48 48 local Yes Yes
Gi1/1/1 49 49 49 0/6 1 49 49 local Yes Yes
Gi1/1/2 50 50 50 0/7 1 50 50 local Yes Yes
Gi1/1/3 51 51 51 0/20 1 51 51 local Yes Yes
Gi1/1/4 52 52 52 0/21 1 52 52 local Yes Yes
Te1/1/1 53 53 53 0/0 1 1 53 local Yes Yes
Te1/1/2 54 54 54 0/14 1 2 54 local Yes Yes
Gi2/0/1 57 57 1 1/1 2 1 1 remote No Yes
Gi2/0/2 58 58 2 1/0 2 2 2 remote No Yes
Gi2/0/3 59 59 3 1/3 2 3 3 remote No Yes
Gi2/0/4 60 60 4 1/2 2 4 4 remote No Yes
Gi2/0/5 61 61 5 1/5 2 5 5 remote No Yes
Gi2/0/6 62 62 6 1/4 2 6 6 remote No Yes
Gi2/0/7 63 63 7 1/9 2 7 7 remote No Yes
Gi2/0/8 64 64 8 1/8 2 8 8 remote No Yes
Gi2/0/9 65 65 9 1/11 2 9 9 remote No Yes
Gi2/0/10 66 66 10 1/10 2 10 10 remote No Yes
Gi2/0/11 67 67 11 1/13 2 11 11 remote No Yes
Gi2/0/12 68 68 12 1/12 2 12 12 remote No Yes
Gi2/0/13 69 69 13 1/15 2 13 13 remote No Yes
Gi2/0/14 70 70 14 1/14 2 14 14 remote No Yes
Gi2/0/15 71 71 15 1/17 2 15 15 remote No Yes
Gi2/0/16 72 72 16 1/16 2 16 16 remote No Yes
Gi2/0/17 73 73 17 1/19 2 17 17 remote No Yes
Gi2/0/18 74 74 18 1/18 2 18 18 remote No Yes
Gi2/0/19 75 75 19 1/23 2 19 19 remote No Yes
Gi2/0/20 76 76 20 1/22 2 20 20 remote No Yes
Gi2/0/21 77 77 21 1/25 2 21 21 remote No Yes
Gi2/0/22 78 78 22 1/24 2 22 22 remote No Yes
Gi2/0/23 79 79 23 1/27 2 23 23 remote No Yes
Gi2/0/24 80 80 24 1/26 2 24 24 remote No Yes
Gi2/0/25 81 81 25 2/1 2 25 25 remote No Yes
Gi2/0/26 82 82 26 2/0 2 26 26 remote No Yes
Gi2/0/27 83 83 27 2/3 2 27 27 remote No Yes
Gi2/0/28 84 84 28 2/2 2 28 28 remote No Yes
Gi2/0/29 85 85 29 2/5 2 29 29 remote No Yes
Gi2/0/30 86 86 30 2/4 2 30 30 remote No Yes
Gi2/0/31 87 87 31 2/9 2 31 31 remote No Yes
Gi2/0/32 88 88 32 2/8 2 32 32 remote No Yes
Gi2/0/33 89 89 33 2/11 2 33 33 remote No Yes
Gi2/0/34 90 90 34 2/10 2 34 34 remote No Yes
Gi2/0/35 91 91 35 2/13 2 35 35 remote No Yes
Gi2/0/36 92 92 36 2/12 2 36 36 remote No Yes
Gi2/0/37 93 93 37 2/15 2 37 37 remote No Yes
Gi2/0/38 94 94 38 2/14 2 38 38 remote No Yes
Gi2/0/39 95 95 39 2/17 2 39 39 remote No Yes
Gi2/0/40 96 96 40 2/16 2 40 40 remote No Yes
Gi2/0/41 97 97 41 2/19 2 41 41 remote No Yes
Gi2/0/42 98 98 42 2/18 2 42 42 remote No Yes
Gi2/0/43 99 99 43 2/23 2 43 43 remote No Yes
Gi2/0/44 100 100 44 2/22 2 44 44 remote No Yes
Gi2/0/45 101 101 45 2/25 2 45 45 remote No Yes
Gi2/0/46 102 102 46 2/24 2 46 46 remote No Yes
Gi2/0/47 103 103 47 2/27 2 47 47 remote No Yes
Gi2/0/48 104 104 48 2/26 2 48 48 remote No Yes
Gi2/1/1 105 105 49 0/6 2 49 49 remote No Yes
Gi2/1/2 106 106 50 0/7 2 50 50 remote No Yes
Gi2/1/3 107 107 51 0/20 2 51 51 remote No Yes
Gi2/1/4 108 108 52 0/21 2 52 52 remote No Yes
Te2/1/1 109 109 53 0/0 2 1 53 remote No Yes
Te2/1/2 110 110 54 0/14 2 2 54 remote No Yes
Gi3/0/1 113 113 1 1/1 3 1 1 remote No Yes
Gi3/0/2 114 114 2 1/0 3 2 2 remote No Yes
Gi3/0/3 115 115 3 1/3 3 3 3 remote No Yes
Gi3/0/4 116 116 4 1/2 3 4 4 remote No Yes
Gi3/0/5 117 117 5 1/5 3 5 5 remote No Yes
Gi3/0/6 118 118 6 1/4 3 6 6 remote No Yes
Gi3/0/7 119 119 7 1/9 3 7 7 remote No Yes
Gi3/0/8 120 120 8 1/8 3 8 8 remote No Yes
Gi3/0/9 121 121 9 1/11 3 9 9 remote No Yes
Gi3/0/10 122 122 10 1/10 3 10 10 remote No Yes
Gi3/0/11 123 123 11 1/13 3 11 11 remote No Yes
Gi3/0/12 124 124 12 1/12 3 12 12 remote No Yes
Gi3/0/13 125 125 13 1/15 3 13 13 remote No Yes
Gi3/0/14 126 126 14 1/14 3 14 14 remote No Yes
Gi3/0/15 127 127 15 1/17 3 15 15 remote No Yes
Gi3/0/16 128 128 16 1/16 3 16 16 remote No Yes
Gi3/0/17 129 129 17 1/19 3 17 17 remote No Yes
Gi3/0/18 130 130 18 1/18 3 18 18 remote No Yes
Gi3/0/19 131 131 19 1/23 3 19 19 remote No Yes
Gi3/0/20 132 132 20 1/22 3 20 20 remote No Yes
Gi3/0/21 133 133 21 1/25 3 21 21 remote No Yes
Gi3/0/22 134 134 22 1/24 3 22 22 remote No Yes
Gi3/0/23 135 135 23 1/27 3 23 23 remote No Yes
Gi3/0/24 136 136 24 1/26 3 24 24 remote No Yes
Gi3/0/25 137 137 25 2/1 3 25 25 remote No Yes
Gi3/0/26 138 138 26 2/0 3 26 26 remote No Yes
Gi3/0/27 139 139 27 2/3 3 27 27 remote No Yes
Gi3/0/28 140 140 28 2/2 3 28 28 remote No Yes
Gi3/0/29 141 141 29 2/5 3 29 29 remote No Yes
Gi3/0/30 142 142 30 2/4 3 30 30 remote No Yes
Gi3/0/31 143 143 31 2/9 3 31 31 remote No Yes
Gi3/0/32 144 144 32 2/8 3 32 32 remote No Yes
Gi3/0/33 145 145 33 2/11 3 33 33 remote No Yes
Gi3/0/34 146 146 34 2/10 3 34 34 remote No Yes
Gi3/0/35 147 147 35 2/13 3 35 35 remote No Yes
Gi3/0/36 148 148 36 2/12 3 36 36 remote No Yes
Gi3/0/37 149 149 37 2/15 3 37 37 remote No Yes
Gi3/0/38 150 150 38 2/14 3 38 38 remote No Yes
Gi3/0/39 151 151 39 2/17 3 39 39 remote No Yes
Gi3/0/40 152 152 40 2/16 3 40 40 remote No Yes
Gi3/0/41 153 153 41 2/19 3 41 41 remote No Yes
Gi3/0/42 154 154 42 2/18 3 42 42 remote No Yes
Gi3/0/43 155 155 43 2/23 3 43 43 remote No Yes
Gi3/0/44 156 156 44 2/22 3 44 44 remote No Yes
Gi3/0/45 157 157 45 2/25 3 45 45 remote No Yes
Gi3/0/46 158 158 46 2/24 3 46 46 remote No Yes
Gi3/0/47 159 159 47 2/27 3 47 47 remote No Yes
Gi3/0/48 160 160 48 2/26 3 48 48 remote No Yes
Gi3/1/1 161 161 49 0/6 3 49 49 remote No Yes
Gi3/1/2 162 162 50 0/7 3 50 50 remote No Yes
Gi3/1/3 163 163 51 0/20 3 51 51 remote No Yes
Gi3/1/4 164 164 52 0/21 3 52 52 remote No Yes
Te3/1/1 165 165 53 0/0 3 1 53 remote No Yes
Te3/1/2 166 166 54 0/14 3 2 54 remote No Yes
Gi4/0/1 169 169 1 1/1 4 1 1 remote No Yes
Gi4/0/2 170 170 2 1/0 4 2 2 remote No Yes
Gi4/0/3 171 171 3 1/3 4 3 3 remote No Yes
Gi4/0/4 172 172 4 1/2 4 4 4 remote No Yes
Gi4/0/5 173 173 5 1/5 4 5 5 remote No Yes
Gi4/0/6 174 174 6 1/4 4 6 6 remote No Yes
Gi4/0/7 175 175 7 1/9 4 7 7 remote No Yes
Gi4/0/8 176 176 8 1/8 4 8 8 remote No Yes
Gi4/0/9 177 177 9 1/11 4 9 9 remote No Yes
Gi4/0/10 178 178 10 1/10 4 10 10 remote No Yes
Gi4/0/11 179 179 11 1/13 4 11 11 remote No Yes
Gi4/0/12 180 180 12 1/12 4 12 12 remote No Yes
Gi4/0/13 181 181 13 1/15 4 13 13 remote No Yes
Gi4/0/14 182 182 14 1/14 4 14 14 remote No Yes
Gi4/0/15 183 183 15 1/17 4 15 15 remote No Yes
Gi4/0/16 184 184 16 1/16 4 16 16 remote No Yes
Gi4/0/17 185 185 17 1/19 4 17 17 remote No Yes
Gi4/0/18 186 186 18 1/18 4 18 18 remote No Yes
Gi4/0/19 187 187 19 1/23 4 19 19 remote No Yes
Gi4/0/20 188 188 20 1/22 4 20 20 remote No Yes
Gi4/0/21 189 189 21 1/25 4 21 21 remote No Yes
Gi4/0/22 190 190 22 1/24 4 22 22 remote No Yes
Gi4/0/23 191 191 23 1/27 4 23 23 remote No Yes
Gi4/0/24 192 192 24 1/26 4 24 24 remote No Yes
Gi4/0/25 193 193 25 2/1 4 25 25 remote No Yes
Gi4/0/26 194 194 26 2/0 4 26 26 remote No Yes
Gi4/0/27 195 195 27 2/3 4 27 27 remote No Yes
Gi4/0/28 196 196 28 2/2 4 28 28 remote No Yes
Gi4/0/29 197 197 29 2/5 4 29 29 remote No Yes
Gi4/0/30 198 198 30 2/4 4 30 30 remote No Yes
Gi4/0/31 199 199 31 2/9 4 31 31 remote No Yes
Gi4/0/32 200 200 32 2/8 4 32 32 remote No Yes
Gi4/0/33 201 201 33 2/11 4 33 33 remote No Yes
Gi4/0/34 202 202 34 2/10 4 34 34 remote No Yes
Gi4/0/35 203 203 35 2/13 4 35 35 remote No Yes
Gi4/0/36 204 204 36 2/12 4 36 36 remote No Yes
Gi4/0/37 205 205 37 2/15 4 37 37 remote No Yes
Gi4/0/38 206 206 38 2/14 4 38 38 remote No Yes
Gi4/0/39 207 207 39 2/17 4 39 39 remote No Yes
Gi4/0/40 208 208 40 2/16 4 40 40 remote No Yes
Gi4/0/41 209 209 41 2/19 4 41 41 remote No Yes
Gi4/0/42 210 210 42 2/18 4 42 42 remote No Yes
Gi4/0/43 211 211 43 2/23 4 43 43 remote No Yes
Gi4/0/44 212 212 44 2/22 4 44 44 remote No Yes
Gi4/0/45 213 213 45 2/25 4 45 45 remote No Yes
Gi4/0/46 214 214 46 2/24 4 46 46 remote No Yes
Gi4/0/47 215 215 47 2/27 4 47 47 remote No Yes
Gi4/0/48 216 216 48 2/26 4 48 48 remote No Yes
Gi4/1/1 217 217 49 0/6 4 49 49 remote No Yes
Gi4/1/2 218 218 50 0/7 4 50 50 remote No Yes
Gi4/1/3 219 219 51 0/20 4 51 51 remote No Yes
Gi4/1/4 220 220 52 0/21 4 52 52 remote No Yes
Te4/1/1 221 221 53 0/0 4 1 53 remote No Yes
Te4/1/2 222 222 54 0/14 4 2 54 remote No Yes
Gi5/0/1 225 225 1 1/1 5 1 1 remote No Yes
Gi5/0/2 226 226 2 1/0 5 2 2 remote No Yes
Gi5/0/3 227 227 3 1/3 5 3 3 remote No Yes
Gi5/0/4 228 228 4 1/2 5 4 4 remote No Yes
Gi5/0/5 229 229 5 1/5 5 5 5 remote No Yes
Gi5/0/6 230 230 6 1/4 5 6 6 remote No Yes
Gi5/0/7 231 231 7 1/9 5 7 7 remote No Yes
Gi5/0/8 232 232 8 1/8 5 8 8 remote No Yes
Gi5/0/9 233 233 9 1/11 5 9 9 remote No Yes
Gi5/0/10 234 234 10 1/10 5 10 10 remote No Yes
Gi5/0/11 235 235 11 1/13 5 11 11 remote No Yes
Gi5/0/12 236 236 12 1/12 5 12 12 remote No Yes
Gi5/0/13 237 237 13 1/15 5 13 13 remote No Yes
Gi5/0/14 238 238 14 1/14 5 14 14 remote No Yes
Gi5/0/15 239 239 15 1/17 5 15 15 remote No Yes
Gi5/0/16 240 240 16 1/16 5 16 16 remote No Yes
Gi5/0/17 241 241 17 1/19 5 17 17 remote No Yes
Gi5/0/18 242 242 18 1/18 5 18 18 remote No Yes
Gi5/0/19 243 243 19 1/23 5 19 19 remote No Yes
Gi5/0/20 244 244 20 1/22 5 20 20 remote No Yes
Gi5/0/22 246 246 22 1/24 5 22 22 remote No Yes
Gi5/0/23 247 247 23 1/27 5 23 23 remote No Yes
Gi5/0/24 248 248 24 1/26 5 24 24 remote No Yes
Gi5/0/25 249 249 25 2/1 5 25 25 remote No Yes
Gi5/0/26 250 250 26 2/0 5 26 26 remote No Yes
Gi5/0/27 251 251 27 2/3 5 27 27 remote No Yes
Gi5/0/28 252 252 28 2/2 5 28 28 remote No Yes
Gi5/0/29 253 253 29 2/5 5 29 29 remote No Yes
Gi5/0/30 254 254 30 2/4 5 30 30 remote No Yes
Gi5/0/31 255 255 31 2/9 5 31 31 remote No Yes
Gi5/0/32 256 256 32 2/8 5 32 32 remote No Yes
Gi5/0/33 257 257 33 2/11 5 33 33 remote No Yes
Gi5/0/34 258 258 34 2/10 5 34 34 remote No Yes
Gi5/0/35 259 259 35 2/13 5 35 35 remote No Yes
Gi5/0/36 260 260 36 2/12 5 36 36 remote No Yes
Gi5/0/37 261 261 37 2/15 5 37 37 remote No Yes
Gi5/0/38 262 262 38 2/14 5 38 38 remote No Yes
Gi5/0/39 263 263 39 2/17 5 39 39 remote No Yes
Gi5/0/40 264 264 40 2/16 5 40 40 remote No Yes
Gi5/0/41 265 265 41 2/19 5 41 41 remote No Yes
Gi5/0/42 266 266 42 2/18 5 42 42 remote No Yes
Gi5/0/43 267 267 43 2/23 5 43 43 remote No Yes
Gi5/0/44 268 268 44 2/22 5 44 44 remote No Yes
Gi5/0/45 269 269 45 2/25 5 45 45 remote No Yes
Gi5/0/46 270 270 46 2/24 5 46 46 remote No Yes
Gi5/0/47 271 271 47 2/27 5 47 47 remote No Yes
Gi5/0/48 272 272 48 2/26 5 48 48 remote No Yes
Gi5/1/1 273 273 49 0/6 5 49 49 remote No Yes
Gi5/1/2 274 274 50 0/7 5 50 50 remote No Yes
Gi5/1/3 275 275 51 0/20 5 51 51 remote No Yes
Gi5/1/4 276 276 52 0/21 5 52 52 remote No Yes
Te5/1/1 277 277 53 0/0 5 1 53 remote No Yes
Te5/1/2 278 278 54 0/14 5 2 54 remote No Yes
Gi6/0/1 281 281 1 1/1 6 1 1 remote No Yes
Gi6/0/2 282 282 2 1/0 6 2 2 remote No Yes
Gi6/0/3 283 283 3 1/3 6 3 3 remote No Yes
Gi6/0/4 284 284 4 1/2 6 4 4 remote No Yes
Gi6/0/5 285 285 5 1/5 6 5 5 remote No Yes
Gi6/0/6 286 286 6 1/4 6 6 6 remote No Yes
Gi6/0/7 287 287 7 1/9 6 7 7 remote No Yes
Gi6/0/8 288 288 8 1/8 6 8 8 remote No Yes
Gi6/0/9 289 289 9 1/11 6 9 9 remote No Yes
Gi6/0/10 290 290 10 1/10 6 10 10 remote No Yes
Gi6/0/11 291 291 11 1/13 6 11 11 remote No Yes
Gi6/0/12 292 292 12 1/12 6 12 12 remote No Yes
Gi6/0/13 293 293 13 1/15 6 13 13 remote No Yes
Gi6/0/14 294 294 14 1/14 6 14 14 remote No Yes
Gi6/0/15 295 295 15 1/17 6 15 15 remote No Yes
Gi6/0/16 296 296 16 1/16 6 16 16 remote No Yes
Gi6/0/17 297 297 17 1/19 6 17 17 remote No Yes
Gi6/0/18 298 298 18 1/18 6 18 18 remote No Yes
Gi6/0/19 299 299 19 1/23 6 19 19 remote No Yes
Gi6/0/20 300 300 20 1/22 6 20 20 remote No Yes
Gi6/0/21 301 301 21 1/25 6 21 21 remote No Yes
Gi6/0/22 302 302 22 1/24 6 22 22 remote No Yes
Gi6/0/23 303 303 23 1/27 6 23 23 remote No Yes
Gi6/0/24 304 304 24 1/26 6 24 24 remote No Yes
Gi6/1/1 305 305 25 0/6 6 25 25 remote No Yes
Gi6/1/2 306 306 26 0/7 6 26 26 remote No Yes
Gi6/1/3 307 307 27 0/20 6 27 27 remote No Yes
Gi6/1/4 308 308 28 0/21 6 28 28 remote No Yes
Te6/1/1 309 309 29 0/0 6 1 29 remote No Yes
Te6/1/2 310 310 30 0/14 6 2 30 remote No Yes
Po1 512 512 0 0/0 10 1 1 local No No
Po2 520 520 0 1/0 10 2 2 local No No
St1 896 896 0 16/0 1 0 0 internal Yes Yes
St2 897 897 0 16/0 2 0 0 internal No Yes
St3 898 898 0 16/0 3 0 0 internal No Yes
St4 899 899 0 16/0 4 0 0 internal No Yes
St5 900 900 0 16/0 5 0 0 internal No Yes
St6 901 901 0 16/0 6 0 0 internal No Yes
Switch_Stack#
Switch_Stack# sh platform pm platform-block
Gi1/0/1 1 1 1 1 1 U 3 2 no 0 0 0 61441 0
Gi1/0/2 2 2 2 1 0 U 3 2 no 0 0 0 61442 0
Gi1/0/3 3 3 3 1 3 U 3 2 no 0 0 0 61443 0
Gi1/0/4 4 4 4 1 2 U 3 2 no 0 0 0 61444 0
Gi1/0/5 5 5 5 1 5 U 2 2 no 0 0 0 61445 0
Gi1/0/6 6 6 6 1 4 U 1 2 no 0 0 0 61446 0
Gi1/0/7 7 7 7 1 9 U 1 2 no 0 0 0 61447 0
Gi1/0/8 8 8 8 1 8 U 3 2 no 0 0 0 61448 0
Gi1/0/9 9 9 9 1 11 U 3 2 no 0 0 0 61449 0
Gi1/0/10 10 10 10 1 10 U 3 2 no 0 0 0 61450 0
Gi1/0/11 11 11 11 1 13 U 1 2 no 0 0 0 61451 0
Gi1/0/12 12 12 12 1 12 U 3 2 no 0 0 0 61452 0
Gi1/0/13 13 13 13 1 15 U 3 2 no 0 0 0 61453 0
Gi1/0/14 14 14 14 1 14 U 3 2 no 0 0 0 61454 0
Gi1/0/15 15 15 15 1 17 U 3 2 no 0 0 0 61455 0
Gi1/0/16 16 16 16 1 16 U 2 2 no 0 0 0 61456 0
Gi1/0/17 17 17 17 1 19 U 3 2 no 0 0 0 61457 0
Gi1/0/18 18 18 18 1 18 D 1 2 no 0 0 0 61458 0
Gi1/0/19 19 19 19 1 23 U 1 2 no 0 0 0 61459 0
Gi1/0/20 20 20 20 1 22 U 3 2 no 0 0 0 61460 0
Gi1/0/21 21 21 21 1 25 U 2 2 no 0 0 0 61461 0
Gi1/0/22 22 22 22 1 24 U 3 2 no 0 0 0 61462 0
Gi1/0/23 23 526 23 1 27 U 3 2 no 0 0 0 61966 0
Gi1/0/24 24 24 24 1 26 U 3 2 no 0 0 0 61464 0
Gi1/0/25 25 25 25 2 1 U 3 2 no 0 0 0 61465 0
Gi1/0/26 26 26 26 2 0 U 3 2 no 0 0 0 61466 0
Gi1/0/27 27 27 27 2 3 U 1 2 no 0 0 0 61467 0
Gi1/0/28 28 28 28 2 2 U 3 2 no 0 0 0 61468 0
Gi1/0/29 29 29 29 2 5 U 3 2 no 0 0 0 61469 0
Gi1/0/30 30 30 30 2 4 U 1 2 no 0 0 0 61470 0
Gi1/0/31 31 31 31 2 9 D 1 2 no 0 0 0 61471 0
Gi1/0/32 32 32 32 2 8 U 2 2 no 0 0 0 61472 0
Gi1/0/33 33 33 33 2 11 U 3 2 no 0 0 0 61473 0
Gi1/0/34 34 34 34 2 10 U 3 2 no 0 0 0 61474 0
Gi1/0/35 35 35 35 2 13 U 3 2 no 0 0 0 61475 0
Gi1/0/36 36 36 36 2 12 U 1 2 no 0 0 0 61476 0
Gi1/0/37 37 37 37 2 15 D 0 0 no 0 0 0 61477 0
Gi1/0/38 38 38 38 2 14 U 1 2 no 0 0 0 61478 0
Gi1/0/39 39 39 39 2 17 U 3 2 no 0 0 0 61479 0
Gi1/0/40 40 40 40 2 16 U 3 2 no 0 0 0 61480 0
Gi1/0/41 41 41 41 2 19 U 3 2 no 0 0 0 61481 0
Gi1/0/42 42 42 42 2 18 D 0 0 no 0 0 0 61482 0
Gi1/0/43 43 43 43 2 23 U 3 2 no 0 0 0 61483 0
Gi1/0/44 44 44 44 2 22 U 3 2 no 0 0 0 61484 0
Gi1/0/45 45 45 45 2 25 U 3 2 no 0 0 0 61485 0
Gi1/0/46 46 46 46 2 24 U 3 2 no 0 0 0 61486 0
Gi1/0/47 47 47 47 2 27 D 0 0 no 0 0 0 61487 0
Gi1/0/48 48 48 48 2 26 D 3 2 no 0 0 0 61488 0
Gi1/1/1 49 49 49 0 6 D 3 2 no 0 0 0 61489 0
Gi1/1/2 50 50 50 0 7 D 0 0 no 0 0 0 61490 0
Gi1/1/3 51 51 51 0 20 D 0 0 no 0 0 0 61491 0
Gi1/1/4 52 512 52 0 21 U 3 2 no 0 0 0 61952 0
Te1/1/1 53 53 53 0 0 D 0 0 no 0 0 0 61493 0
Te1/1/2 54 54 54 0 14 D 0 0 no 0 0 0 61494 0
Gi2/0/1 57 57 1 1 1 R U 0 0 no 0 0 0 61497 0
Gi2/0/2 58 58 2 1 0 R U 0 0 no 0 0 0 61498 0
Gi2/0/3 59 59 3 1 3 R U 0 0 no 0 0 0 61499 0
Gi2/0/4 60 60 4 1 2 R U 0 0 no 0 0 0 61500 0
Gi2/0/5 61 61 5 1 5 R D 0 0 no 0 0 0 61501 0
Gi2/0/6 62 62 6 1 4 R U 0 0 no 0 0 0 61502 0
Gi2/0/7 63 63 7 1 9 R U 0 0 no 0 0 0 61503 0
Gi2/0/8 64 64 8 1 8 R U 0 0 no 0 0 0 61504 0
Gi2/0/9 65 65 9 1 11 R U 0 0 no 0 0 0 61505 0
Gi2/0/10 66 66 10 1 10 R U 0 0 no 0 0 0 61506 0
Gi2/0/11 67 67 11 1 13 R D 0 0 no 0 0 0 61507 0
Gi2/0/12 68 68 12 1 12 R D 0 0 no 0 0 0 61508 0
Gi2/0/13 69 69 13 1 15 R U 0 0 no 0 0 0 61509 0
Gi2/0/14 70 70 14 1 14 R D 0 0 no 0 0 0 61510 0
Gi2/0/15 71 71 15 1 17 R U 0 0 no 0 0 0 61511 0
Gi2/0/16 72 72 16 1 16 R U 0 0 no 0 0 0 61512 0
Gi2/0/17 73 73 17 1 19 R D 0 0 no 0 0 0 61513 0
Gi2/0/18 74 74 18 1 18 R D 0 0 no 0 0 0 61514 0
Gi2/0/19 75 75 19 1 23 R U 0 0 no 0 0 0 61515 0
Gi2/0/20 76 76 20 1 22 R U 0 0 no 0 0 0 61516 0
Gi2/0/21 77 77 21 1 25 R D 0 0 no 0 0 0 61517 0
Gi2/0/22 78 78 22 1 24 R U 0 0 no 0 0 0 61518 0
Gi2/0/23 79 79 23 1 27 R U 0 0 no 0 0 0 61519 0
Gi2/0/24 80 80 24 1 26 R U 0 0 no 0 0 0 61520 0
Gi2/0/25 81 81 25 2 1 R U 0 0 no 0 0 0 61521 0
Gi2/0/26 82 82 26 2 0 R U 0 0 no 0 0 0 61522 0
Gi2/0/27 83 83 27 2 3 R D 0 0 no 0 0 0 61523 0
Gi2/0/28 84 84 28 2 2 R U 0 0 no 0 0 0 61524 0
Gi2/0/29 85 85 29 2 5 R U 0 0 no 0 0 0 61525 0
Gi2/0/30 86 86 30 2 4 R U 0 0 no 0 0 0 61526 0
Gi2/0/31 87 87 31 2 9 R U 0 0 no 0 0 0 61527 0
Gi2/0/32 88 88 32 2 8 R U 0 0 no 0 0 0 61528 0
Gi2/0/33 89 89 33 2 11 R U 0 0 no 0 0 0 61529 0
Gi2/0/34 90 90 34 2 10 R D 0 0 no 0 0 0 61530 0
Gi2/0/35 91 91 35 2 13 R U 0 0 no 0 0 0 61531 0
Gi2/0/36 92 92 36 2 12 R D 0 0 no 0 0 0 61532 0
Gi2/0/37 93 93 37 2 15 R D 0 0 no 0 0 0 61533 0
Gi2/0/38 94 94 38 2 14 R D 0 0 no 0 0 0 61534 0
Gi2/0/39 95 95 39 2 17 R U 0 0 no 0 0 0 61535 0
Gi2/0/40 96 96 40 2 16 R D 0 0 no 0 0 0 61536 0
Gi2/0/41 97 97 41 2 19 R U 0 0 no 0 0 0 61537 0
Gi2/0/42 98 98 42 2 18 R U 0 0 no 0 0 0 61538 0
Gi2/0/43 99 99 43 2 23 R U 0 0 no 0 0 0 61539 0
Gi2/0/44 100 100 44 2 22 R U 0 0 no 0 0 0 61540 0
Gi2/0/45 101 101 45 2 25 R D 0 0 no 0 0 0 61541 0
Gi2/0/46 102 102 46 2 24 R D 0 0 no 0 0 0 61542 0
Gi2/0/47 103 103 47 2 27 R U 0 0 no 0 0 0 61543 0
Gi2/0/48 104 104 48 2 26 R U 0 0 no 0 0 0 61544 0
Gi2/1/1 105 105 49 0 6 R D 0 0 no 0 0 0 61545 0
Gi2/1/2 106 106 50 0 7 R D 0 0 no 0 0 0 61546 0
Gi2/1/3 107 107 51 0 20 R D 0 0 no 0 0 0 61547 0
Gi2/1/4 108 108 52 0 21 R D 0 0 no 0 0 0 61548 0
Te2/1/1 109 109 53 0 0 R D 0 0 no 0 0 0 61549 0
Te2/1/2 110 110 54 0 14 R D 0 0 no 0 0 0 61550 0
Gi3/0/1 113 113 1 1 1 R U 0 0 no 0 0 0 61553 0
Gi3/0/2 114 114 2 1 0 R U 0 0 no 0 0 0 61554 0
Gi3/0/3 115 115 3 1 3 R U 0 0 no 0 0 0 61555 0
Gi3/0/4 116 116 4 1 2 R U 0 0 no 0 0 0 61556 0
Gi3/0/5 117 117 5 1 5 R U 0 0 no 0 0 0 61557 0
Gi3/0/6 118 118 6 1 4 R U 0 0 no 0 0 0 61558 0
Gi3/0/7 119 119 7 1 9 R U 0 0 no 0 0 0 61559 0
Gi3/0/8 120 120 8 1 8 R U 0 0 no 0 0 0 61560 0
Gi3/0/9 121 121 9 1 11 R D 0 0 no 0 0 0 61561 0
Gi3/0/10 122 122 10 1 10 R U 0 0 no 0 0 0 61562 0
Gi3/0/11 123 123 11 1 13 R U 0 0 no 0 0 0 61563 0
Gi3/0/12 124 124 12 1 12 R D 0 0 no 0 0 0 61564 0
Gi3/0/13 125 125 13 1 15 R U 0 0 no 0 0 0 61565 0
Gi3/0/14 126 126 14 1 14 R U 0 0 no 0 0 0 61566 0
Gi3/0/15 127 127 15 1 17 R U 0 0 no 0 0 0 61567 0
Gi3/0/16 128 128 16 1 16 R D 0 0 no 0 0 0 61568 0
Gi3/0/17 129 129 17 1 19 R U 0 0 no 0 0 0 61569 0
Gi3/0/18 130 130 18 1 18 R D 0 0 no 0 0 0 61570 0
Gi3/0/19 131 131 19 1 23 R D 0 0 no 0 0 0 61571 0
Gi3/0/20 132 132 20 1 22 R U 0 0 no 0 0 0 61572 0
Gi3/0/21 133 133 21 1 25 R U 0 0 no 0 0 0 61573 0
Gi3/0/22 134 134 22 1 24 R U 0 0 no 0 0 0 61574 0
Gi3/0/23 135 135 23 1 27 R D 0 0 no 0 0 0 61575 0
Gi3/0/24 136 136 24 1 26 R U 0 0 no 0 0 0 61576 0
Gi3/0/25 137 137 25 2 1 R U 0 0 no 0 0 0 61577 0
Gi3/0/26 138 138 26 2 0 R D 0 0 no 0 0 0 61578 0
Gi3/0/27 139 139 27 2 3 R U 0 0 no 0 0 0 61579 0
Gi3/0/28 140 140 28 2 2 R U 0 0 no 0 0 0 61580 0
Gi3/0/29 141 141 29 2 5 R U 0 0 no 0 0 0 61581 0
Gi3/0/30 142 142 30 2 4 R U 0 0 no 0 0 0 61582 0
Gi3/0/31 143 143 31 2 9 R U 0 0 no 0 0 0 61583 0
Gi3/0/32 144 144 32 2 8 R U 0 0 no 0 0 0 61584 0
Gi3/0/33 145 145 33 2 11 R U 0 0 no 0 0 0 61585 0
Gi3/0/34 146 146 34 2 10 R U 0 0 no 0 0 0 61586 0
Gi3/0/35 147 147 35 2 13 R U 0 0 no 0 0 0 61587 0
Gi3/0/36 148 148 36 2 12 R U 0 0 no 0 0 0 61588 0
Gi3/0/37 149 149 37 2 15 R U 0 0 no 0 0 0 61589 0
Gi3/0/38 150 150 38 2 14 R D 0 0 no 0 0 0 61590 0
Gi3/0/39 151 151 39 2 17 R U 0 0 no 0 0 0 61591 0
Gi3/0/40 152 152 40 2 16 R U 0 0 no 0 0 0 61592 0
Gi3/0/41 153 153 41 2 19 R U 0 0 no 0 0 0 61593 0
Gi3/0/42 154 154 42 2 18 R D 0 0 no 0 0 0 61594 0
Gi3/0/43 155 155 43 2 23 R U 0 0 no 0 0 0 61595 0
Gi3/0/44 156 156 44 2 22 R U 0 0 no 0 0 0 61596 0
Gi3/0/45 157 157 45 2 25 R U 0 0 no 0 0 0 61597 0
Gi3/0/46 158 158 46 2 24 R D 0 0 no 0 0 0 61598 0
Gi3/0/47 159 159 47 2 27 R U 0 0 no 0 0 0 61599 0
Gi3/0/48 160 160 48 2 26 R D 0 0 no 0 0 0 61600 0
Gi3/1/1 161 161 49 0 6 R D 0 0 no 0 0 0 61601 0
Gi3/1/2 162 162 50 0 7 R D 0 0 no 0 0 0 61602 0
Gi3/1/3 163 163 51 0 20 R D 0 0 no 0 0 0 61603 0
Gi3/1/4 164 164 52 0 21 R D 0 0 no 0 0 0 61604 0
Te3/1/1 165 165 53 0 0 R D 0 0 no 0 0 0 61605 0
Te3/1/2 166 166 54 0 14 R D 0 0 no 0 0 0 61606 0
Gi4/0/1 169 169 1 1 1 R U 0 0 no 0 0 0 61609 0
Gi4/0/2 170 170 2 1 0 R U 0 0 no 0 0 0 61610 0
Gi4/0/3 171 171 3 1 3 R U 0 0 no 0 0 0 61611 0
Gi4/0/4 172 172 4 1 2 R U 0 0 no 0 0 0 61612 0
Gi4/0/5 173 173 5 1 5 R U 0 0 no 0 0 0 61613 0
Gi4/0/6 174 174 6 1 4 R U 0 0 no 0 0 0 61614 0
Gi4/0/7 175 175 7 1 9 R D 0 0 no 0 0 0 61615 0
Gi4/0/8 176 176 8 1 8 R U 0 0 no 0 0 0 61616 0
Gi4/0/9 177 177 9 1 11 R U 0 0 no 0 0 0 61617 0
Gi4/0/10 178 178 10 1 10 R U 0 0 no 0 0 0 61618 0
Gi4/0/11 179 179 11 1 13 R U 0 0 no 0 0 0 61619 0
Gi4/0/12 180 180 12 1 12 R D 0 0 no 0 0 0 61620 0
Gi4/0/13 181 181 13 1 15 R D 0 0 no 0 0 0 61621 0
Gi4/0/14 182 182 14 1 14 R U 0 0 no 0 0 0 61622 0
Gi4/0/15 183 183 15 1 17 R U 0 0 no 0 0 0 61623 0
Gi4/0/16 184 184 16 1 16 R U 0 0 no 0 0 0 61624 0
Gi4/0/17 185 185 17 1 19 R U 0 0 no 0 0 0 61625 0
Gi4/0/18 186 186 18 1 18 R U 0 0 no 0 0 0 61626 0
Gi4/0/19 187 187 19 1 23 R U 0 0 no 0 0 0 61627 0
Gi4/0/20 188 188 20 1 22 R U 0 0 no 0 0 0 61628 0
Gi4/0/21 189 189 21 1 25 R U 0 0 no 0 0 0 61629 0
Gi4/0/22 190 190 22 1 24 R U 0 0 no 0 0 0 61630 0
Gi4/0/23 191 191 23 1 27 R U 0 0 no 0 0 0 61631 0
Gi4/0/24 192 192 24 1 26 R U 0 0 no 0 0 0 61632 0
Gi4/0/25 193 193 25 2 1 R D 0 0 no 0 0 0 61633 0
Gi4/0/26 194 194 26 2 0 R D 0 0 no 0 0 0 61634 0
Gi4/0/27 195 195 27 2 3 R D 0 0 no 0 0 0 61635 0
Gi4/0/28 196 196 28 2 2 R U 0 0 no 0 0 0 61636 0
Gi4/0/29 197 197 29 2 5 R D 0 0 no 0 0 0 61637 0
Gi4/0/30 198 198 30 2 4 R D 0 0 no 0 0 0 61638 0
Gi4/0/31 199 199 31 2 9 R U 0 0 no 0 0 0 61639 0
Gi4/0/32 200 200 32 2 8 R U 0 0 no 0 0 0 61640 0
Gi4/0/33 201 201 33 2 11 R U 0 0 no 0 0 0 61641 0
Gi4/0/34 202 202 34 2 10 R U 0 0 no 0 0 0 61642 0
Gi4/0/35 203 203 35 2 13 R U 0 0 no 0 0 0 61643 0
Gi4/0/36 204 204 36 2 12 R U 0 0 no 0 0 0 61644 0
Gi4/0/37 205 205 37 2 15 R U 0 0 no 0 0 0 61645 0
Gi4/0/38 206 206 38 2 14 R U 0 0 no 0 0 0 61646 0
Gi4/0/39 207 207 39 2 17 R D 0 0 no 0 0 0 61647 0
Gi4/0/40 208 208 40 2 16 R U 0 0 no 0 0 0 61648 0
Gi4/0/41 209 209 41 2 19 R U 0 0 no 0 0 0 61649 0
Gi4/0/42 210 210 42 2 18 R U 0 0 no 0 0 0 61650 0
Gi4/0/43 211 211 43 2 23 R U 0 0 no 0 0 0 61651 0
Gi4/0/44 212 212 44 2 22 R D 0 0 no 0 0 0 61652 0
Gi4/0/45 213 213 45 2 25 R U 0 0 no 0 0 0 61653 0
Gi4/0/46 214 214 46 2 24 R U 0 0 no 0 0 0 61654 0
Gi4/0/47 215 215 47 2 27 R U 0 0 no 0 0 0 61655 0
Gi4/0/48 216 216 48 2 26 R D 0 0 no 0 0 0 61656 0
Gi4/1/1 217 217 49 0 6 R D 0 0 no 0 0 0 61657 0
Gi4/1/2 218 218 50 0 7 R D 0 0 no 0 0 0 61658 0
Gi4/1/3 219 219 51 0 20 R D 0 0 no 0 0 0 61659 0
Gi4/1/4 220 220 52 0 21 R D 0 0 no 0 0 0 61660 0
Te4/1/1 221 221 53 0 0 R D 0 0 no 0 0 0 61661 0
Te4/1/2 222 222 54 0 14 R D 0 0 no 0 0 0 61662 0
Gi5/0/1 225 225 1 1 1 R D 0 0 no 0 0 0 61665 0
Gi5/0/2 226 226 2 1 0 R U 0 0 no 0 0 0 61666 0
Gi5/0/3 227 227 3 1 3 R D 0 0 no 0 0 0 61667 0
Gi5/0/4 228 228 4 1 2 R U 0 0 no 0 0 0 61668 0
Gi5/0/5 229 229 5 1 5 R D 0 0 no 0 0 0 61669 0
Gi5/0/6 230 230 6 1 4 R U 0 0 no 0 0 0 61670 0
Gi5/0/7 231 231 7 1 9 R D 0 0 no 0 0 0 61671 0
Gi5/0/8 232 232 8 1 8 R U 0 0 no 0 0 0 61672 0
Gi5/0/9 233 233 9 1 11 R U 0 0 no 0 0 0 61673 0
Gi5/0/10 234 234 10 1 10 R D 0 0 no 0 0 0 61674 0
Gi5/0/11 235 235 11 1 13 R D 0 0 no 0 0 0 61675 0
Gi5/0/12 236 236 12 1 12 R U 0 0 no 0 0 0 61676 0
Gi5/0/13 237 237 13 1 15 R D 0 0 no 0 0 0 61677 0
Gi5/0/14 238 238 14 1 14 R U 0 0 no 0 0 0 61678 0
Gi5/0/15 239 239 15 1 17 R D 0 0 no 0 0 0 61679 0
Gi5/0/16 240 240 16 1 16 R U 0 0 no 0 0 0 61680 0
Gi5/0/17 241 241 17 1 19 R U 0 0 no 0 0 0 61681 0
Gi5/0/18 242 242 18 1 18 R D 0 0 no 0 0 0 61682 0
Gi5/0/19 243 243 19 1 23 R D 0 0 no 0 0 0 61683 0
Gi5/0/20 244 244 20 1 22 R U 0 0 no 0 0 0 61684 0
Gi5/0/22 246 246 22 1 24 R D 0 0 no 0 0 0 61686 0
Gi5/0/23 247 247 23 1 27 R D 0 0 no 0 0 0 61687 0
Gi5/0/24 248 248 24 1 26 R U 0 0 no 0 0 0 61688 0
Gi5/0/25 249 249 25 2 1 R D 0 0 no 0 0 0 61689 0
Gi5/0/26 250 250 26 2 0 R U 0 0 no 0 0 0 61690 0
Gi5/0/27 251 251 27 2 3 R U 0 0 no 0 0 0 61691 0
Gi5/0/28 252 252 28 2 2 R U 0 0 no 0 0 0 61692 0
Gi5/0/29 253 253 29 2 5 R U 0 0 no 0 0 0 61693 0
Gi5/0/30 254 254 30 2 4 R U 0 0 no 0 0 0 61694 0
Gi5/0/31 255 255 31 2 9 R U 0 0 no 0 0 0 61695 0
Gi5/0/32 256 256 32 2 8 R U 0 0 no 0 0 0 61696 0
Gi5/0/33 257 257 33 2 11 R U 0 0 no 0 0 0 61697 0
Gi5/0/34 258 258 34 2 10 R D 0 0 no 0 0 0 61698 0
Gi5/0/35 259 259 35 2 13 R U 0 0 no 0 0 0 61699 0
Gi5/0/36 260 260 36 2 12 R U 0 0 no 0 0 0 61700 0
Gi5/0/37 261 261 37 2 15 R U 0 0 no 0 0 0 61701 0
Gi5/0/38 262 262 38 2 14 R U 0 0 no 0 0 0 61702 0
Gi5/0/39 263 263 39 2 17 R D 0 0 no 0 0 0 61703 0
Gi5/0/40 264 264 40 2 16 R D 0 0 no 0 0 0 61704 0
Gi5/0/41 265 265 41 2 19 R D 0 0 no 0 0 0 61705 0
Gi5/0/42 266 266 42 2 18 R D 0 0 no 0 0 0 61706 0
Gi5/0/43 267 267 43 2 23 R U 0 0 no 0 0 0 61707 0
Gi5/0/44 268 268 44 2 22 R D 0 0 no 0 0 0 61708 0
Gi5/0/45 269 269 45 2 25 R U 0 0 no 0 0 0 61709 0
Gi5/0/46 270 270 46 2 24 R D 0 0 no 0 0 0 61710 0
Gi5/0/47 271 271 47 2 27 R U 0 0 no 0 0 0 61711 0
Gi5/0/48 272 272 48 2 26 R D 0 0 no 0 0 0 61712 0
Gi5/1/1 273 273 49 0 6 R D 0 0 no 0 0 0 61713 0
Gi5/1/2 274 274 50 0 7 R D 0 0 no 0 0 0 61714 0
Gi5/1/3 275 275 51 0 20 R D 0 0 no 0 0 0 61715 0
Gi5/1/4 276 514 52 0 21 R U 0 0 no 0 0 0 61954 0
Te5/1/1 277 277 53 0 0 R D 0 0 no 0 0 0 61717 0
Te5/1/2 278 278 54 0 14 R D 0 0 no 0 0 0 61718 0
Gi6/0/1 281 281 1 1 1 R D 0 0 no 0 0 0 61721 0
Gi6/0/2 282 282 2 1 0 R U 0 0 no 0 0 0 61722 0
Gi6/0/3 283 283 3 1 3 R U 0 0 no 0 0 0 61723 0
Gi6/0/4 284 284 4 1 2 R U 0 0 no 0 0 0 61724 0
Gi6/0/5 285 285 5 1 5 R U 0 0 no 0 0 0 61725 0
Gi6/0/6 286 286 6 1 4 R U 0 0 no 0 0 0 61726 0
Gi6/0/7 287 287 7 1 9 R U 0 0 no 0 0 0 61727 0
Gi6/0/8 288 288 8 1 8 R U 0 0 no 0 0 0 61728 0
Gi6/0/9 289 289 9 1 11 R U 0 0 no 0 0 0 61729 0
Gi6/0/10 290 290 10 1 10 R U 0 0 no 0 0 0 61730 0
Gi6/0/11 291 291 11 1 13 R U 0 0 no 0 0 0 61731 0
Gi6/0/12 292 292 12 1 12 R U 0 0 no 0 0 0 61732 0
Gi6/0/13 293 293 13 1 15 R U 0 0 no 0 0 0 61733 0
Gi6/0/14 294 294 14 1 14 R U 0 0 no 0 0 0 61734 0
Gi6/0/15 295 295 15 1 17 R U 0 0 no 0 0 0 61735 0
Gi6/0/16 296 296 16 1 16 R U 0 0 no 0 0 0 61736 0
Gi6/0/17 297 297 17 1 19 R U 0 0 no 0 0 0 61737 0
Gi6/0/18 298 298 18 1 18 R U 0 0 no 0 0 0 61738 0
Gi6/0/19 299 299 19 1 23 R U 0 0 no 0 0 0 61739 0
Gi6/0/20 300 300 20 1 22 R U 0 0 no 0 0 0 61740 0
Gi6/0/21 301 301 21 1 25 R U 0 0 no 0 0 0 61741 0
Gi6/0/22 302 302 22 1 24 R U 0 0 no 0 0 0 61742 0
Gi6/0/23 303 303 23 1 27 R U 0 0 no 0 0 0 61743 0
Gi6/0/24 304 304 24 1 26 R D 0 0 no 0 0 0 61744 0
Gi6/1/1 305 305 25 0 6 R D 0 0 no 0 0 0 61745 0
Gi6/1/2 306 306 26 0 7 R D 0 0 no 0 0 0 61746 0
Gi6/1/3 307 307 27 0 20 R D 0 0 no 0 0 0 61747 0
Gi6/1/4 308 308 28 0 21 R D 0 0 no 0 0 0 61748 0
Te6/1/1 309 309 29 0 0 R D 0 0 no 0 0 0 61749 0
Te6/1/2 310 310 30 0 14 R D 0 0 no 0 0 0 61750 0
Po1 512 512 0 0 0 U 0 0 no 0 0 0 61952 0
Po2 520 520 0 0 0 U 0 0 no 0 0 0 61960 0
Switch_Stack#sh platform port-asic stats drop asic 1
Port-asic Port Drop Statistics - Summary
RxQueue Drop Statistics Slice0
RxQueue 0 Drop Stats Slice0: 0
RxQueue 1 Drop Stats Slice0: 0
RxQueue 2 Drop Stats Slice0: 0
RxQueue 3 Drop Stats Slice0: 0
RxQueue Drop Statistics Slice1
RxQueue 0 Drop Stats Slice1: 0
RxQueue 1 Drop Stats Slice1: 0
RxQueue 2 Drop Stats Slice1: 0
RxQueue 3 Drop Stats Slice1: 0
Port 0 TxQueue Drop Stats: 37224
Port 1 TxQueue Drop Stats: 56
Port 2 TxQueue Drop Stats: 16365
Port 3 TxQueue Drop Stats: 59293
Port 4 TxQueue Drop Stats: 129024
Port 5 TxQueue Drop Stats: 15467
Port 6 TxQueue Drop Stats: 0
Port 7 TxQueue Drop Stats: 0
Port 8 TxQueue Drop Stats: 138711
Port 9 TxQueue Drop Stats: 156573
Port 10 TxQueue Drop Stats: 0
Port 11 TxQueue Drop Stats: 95177
Port 12 TxQueue Drop Stats: 14900
Port 13 TxQueue Drop Stats: 126055
Port 14 TxQueue Drop Stats: 139008
Port 15 TxQueue Drop Stats: 120857
Port 16 TxQueue Drop Stats: 25388
Port 17 TxQueue Drop Stats: 118325
Port 18 TxQueue Drop Stats: 50080
Port 19 TxQueue Drop Stats: 0
Port 20 TxQueue Drop Stats: 0
Port 21 TxQueue Drop Stats: 0
Port 22 TxQueue Drop Stats: 114898
Port 23 TxQueue Drop Stats: 98839
Port 24 TxQueue Drop Stats: 8930
Port 25 TxQueue Drop Stats: 74349
Port 26 TxQueue Drop Stats: 33819
Port 27 TxQueue Drop Stats: 0
Supervisor TxQueue Drop Statistics
Queue 0: 0
Queue 1: 0
Queue 2: 0
Queue 3: 0
Queue 4: 0
Queue 5: 0
Queue 6: 0
Queue 7: 0
Queue 8: 0
Queue 9: 0
Queue 10: 0
Queue 11: 0
Queue 12: 0
Queue 13: 0
Queue 14: 0
Queue 15: 0
Port-asic Port Drop Statistics - Details
Queue 0 DropThreshold 0 0 DropThreshold 1 0 DropThreshold 2 0
Queue 1 DropThreshold 0 0 DropThreshold 1 0 DropThreshold 2 0
Queue 2 DropThreshold 0 0 DropThreshold 1 0 DropThreshold 2 0
Queue 3 DropThreshold 0 0 DropThreshold 1 0 DropThreshold 2 0
Queue 0
DropThreshold 0 0
DropThreshold 1 0
DropThreshold 2 0
Queue 1
DropThreshold 0 0
DropThreshold 1 0
DropThreshold 2 0
Queue 2
DropThreshold 0 0
DropThreshold 1 0
DropThreshold 2 0
Queue 3
DropThreshold 0 0
DropThreshold 1 0
DropThreshold 2 0
Port 0 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 37213
Weight 1 Frames 11
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 1 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 56
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 2 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 16365
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 3 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 59283
Weight 1 Frames 10
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 4 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 128991
Weight 1 Frames 33
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 5 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 15465
Weight 1 Frames 2
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 6 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 7 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 8 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 138678
Weight 1 Frames 33
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 9 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 156537
Weight 1 Frames 36
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 10 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 11 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 95148
Weight 1 Frames 29
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 12 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 14895
Weight 1 Frames 5
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 13 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 126027
Weight 1 Frames 28
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 14 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 138975
Weight 1 Frames 33
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 15 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 120828
Weight 1 Frames 29
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 16 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 25386
Weight 1 Frames 2
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 17 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 118295
Weight 1 Frames 30
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 18 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 50077
Weight 1 Frames 3
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 19 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 20 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 21 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 22 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 114872
Weight 1 Frames 26
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 23 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 98812
Weight 1 Frames 27
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 24 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 8930
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 25 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 74334
Weight 1 Frames 15
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 26 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 33809
Weight 1 Frames 10
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 27 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 0: 0
Queue 1: 0
Queue 2: 0
Queue 3: 0
Queue 4: 0
Queue 5: 0
Queue 6: 0
Queue 7: 0
Queue 8: 0
Queue 9: 0
Queue 10: 0
Queue 11: 0
Queue 12: 0
Queue 13: 0
Queue 14: 0
Queue 15: 0
6 Replies 6
I can try and help you with the output drops by adjusting the queues. For that, can you post the output of the three commands below:
show mls qos int gi5/0/21 statistics
show mls qos maps dscp-output-q
show mls qos queue-set
Hi George
Thanks for your offer to assist. Output of the commands is below. FYI I will need to configure QoS for frames/packets containing  sip/rtp in near future
DSCP
SIP CS3 24
RTP EF 46
video af41
802.1p/CoS
SIP 3
audio RTP 5
Switch_Stack#sh run | i mls
mls qos
Switch_Stack#show mls qos int gi5/0/21 statistics
dscp: incoming
0 - 4 : 331512033 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 0 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 9827433 0 0 0 24
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 260616843 0 0 0 0
5 - 7 : 0 0 0
cos: outgoing
0 - 4 : 514261572 0 0 0 23
5 - 7 : 0 3787617 39076046
queue 0: 0 0 0
queue 1: 4106640982 294015071 39076506
queue 2: 0 0 0
queue 3: 23 0 594953874
queue 0: 0 0 0
queue 1: 99332 25 0
queue 2: 0 0 0
queue 3: 0 0 0
Switch_Stack# show mls qos maps dscp-output-q
Dscp-outputq-threshold map:
d1 :d2 0 1 2 3 4 5 6 7 8 9
0 : 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01
1 : 02-01 02-01 02-01 02-01 02-01 02-01 03-01 03-01 03-01 03-01
2 : 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01
3 : 03-01 03-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
4 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 04-01 04-01
5 : 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
6 : 04-01 04-01 04-01 04-01
Switch_Stack# show mls qos queue-set
Queueset: 1
Queue : 1 2 3 4
buffers : 25 25 25 25
threshold1: 100 200 100 100
threshold2: 100 200 100 100
reserved : 50 50 50 50
maximum : 400 400 400 400
Queueset: 2
Queue : 1 2 3 4
here is the procedure to tune the queue on your interface (the procedure used is described in the link at the bottom of this post):
Make sure queue set 2 is assigned to interface GigabitEthernet5/0/21
Switch_Stack(config)#int gi5/0/21
Switch_Stack(config-if)#queue-set 2
This is what the interface configuration should look like:
Switch_Stack#show run int gi5/0/21
switchport mode access
mls qos trust dscp
queue-set 2
Configure the below:
Switch_Stack(config)#mls qos queue-set output 2 buffers 10 50 10 30
Switch_Stack(config)#mls qos queue-set output 2 threshold 2 3100 3100 100 3200
And verify if the values have been assigned correctly:
Switch#show mls qos queue-set
Queueset: 1
Queue : 1 2 3 4
Queueset: 2
Queue : 1 2 3 4
buffers : 10 50 10 30
threshold1: 3100 100 100 100
threshold2: 3100 100 100 100
reserved : 100 50 50 50
maximum : 3200 400 400 400
Output Drops Due to QoS on Access Layer Switches Troubleshooting TechNote
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/116089-technote-switches-output-drops-qos-00.html
I just wanted to note, what Georg is suggesting, may indeed reduce drops in one queue, but it may create drops in other queues.
As I noted in my other post, the 3750 series is a bit infamous on the subject of queue drops especially when QoS is enabled.
Often tuning QoS is an on-going interactive effort, as you try to find the optimal settings for your device(s) and your traffic.
Again, I suggest you might search this site for additional posts on this subject.  I recall some of my posts show how to configure the 3750 series to work more like the earlier 3K switches, those that used more of a dynamic pool approach.  Depending on your traffic, that approach might work very well (might not too - again, QoS tuning rarely one size fits all).
Thanks Georg and Joseph for you replies.
George : I shall be applying the suggested config this week. Can you please help me understand more by explaning the suggested config change.
- The copy of output from the command "show mls qos int gi5/0/21 statistics " is below. Am I correct in understanding that queue set one's queue 1 had packets queues at threshold1, threshold2, threshold3. Whereas queuesets two queue 1 had 99332 packets queued at threshold1 and 25 at threshold2 and none for threshold3
queue 0: 0 0 0
queue 2: 0 0 0
queue 0: 0 0 0
queue 1: 99332 25 0
queue 2: 0 0 0
queue 3: 0 0 0
And for this reason (less enqueued) you have suggested to use queue set 2 for interface GigabitEthernet5/0/21 and set buffer value 50 for queue 2. I guess that queue1 in output of command show mls qos int gi5/0/21 statistics equates to queue 2 in the command (config)#mls qos queue-set output 2 buffers 10 50 10 30 ?
-Secondly this is a stack of six switches so should I set half of ports to use queue set 1 and remaining half of the ports to queue set 2
Joseph: I agree that tehre me be an adverse effect after applying the config. I will keep and eye and optimise as required. Moreover I will search for your posts regarding 3750 too.
Joseph W. Doherty
The 3750 series is a bit infamous on the subject of interface drops especially when QoS is enabled and even more especially if QoS is running with default settings.
Suggest you search these forums a bit. I, and others, have posted on this subject.
