Stacked switch to two firewalls
Ji-Won Park
Hi everyone,
I'd like to get some idea of different ways to design the attached topology.
There is a stacked switches 3750, and two PAN firewalls. I'd like to connect each interface on different switch stack directly to the firewalls. There is no switch in between.
Your idea would be much appreciated.
int g1/0/48, g2/0/48
  sw mo acc
  sw acc v 99
  switchport nonegotiate
What kind of configuration needs to be done on F/W side?
nothing special. IP-addresses in the 10.1.99.0/28 subnet with 10.1.99.1 as the gateway.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
You can do it directly as in your drawing. Thats a quite common setup.
Thanks for the feedback...
Should I create an SVI for V99 and make them access ports?
int vlan99
ip add 10.1.99.1 255.255.255.240
sw mo acc
sw acc v 99
Would this work?
  sw mo acc
  sw acc v 99
Cool. I just wanted to confirm before I touch the devices.
Thanks a lot.
