Stacking 4500x(VSS) 16 & 32 port
Ninjabean
A customer is wanting to VSS their 16 port 4500x with a new 32 port. They also want to add an 8 gig module to the 16, making it a 24 port with a 32 port. Is this possible? I was under the impression that the 4500's must be the exact same port model to VSS.
Reza Sharifi
Yes, you can mix them.
from the datasheet:
Any two Cisco Catalyst 4500-X Series Switches can be pooled together into a VSS. The two switches are connected with 10 Gigabit Ethernet links called Virtual Switch Links (VSLs). Once a VSS is created, it acts as a single virtual Cisco Catalyst switch delivering the following benefits:
link:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-x-series-switches/data_sheet_c78-696791.html
Reza Sharifi
from the datasheet:
link:
Thank you! I reviewed the datasheet but could not find that information for the life of me.
I completely understand.  Sometimes, I have a hard time finding something even after reading the whole document.
Good Luck!
Think the datasheet looks different now, "Two Cisco Catalyst 4500-X Series Switches of the same model can be pooled together into a VSS. The two switches are connected with 10 Gigabit Ethernet links called Virtual Switch Links (VSLs). Once a VSS is created, it acts as a single virtual Cisco Catalyst switch delivering the following benefits:"
I believe this means they are not able to form a VSS
