Stacking a 3750G
Andy White
Level 3
Level 3
I am going to be stacking a new 24 port C3750GTS switch with another of the same model. I have done this before and I have set the priority of the current live switch to 5 and I will provision the 2 switch before or after I use the stack cable.  I have a couple of questions:
1.) Both the new and older switch are running IOS 12.2(35)SE5 - C3750-IPBASE-M, is it worth upgrading or leave them as they are?
2.) Do both switches have t use the same IOS version? or Image?
3.) I have read you can stack different models togther, which I didn't think possible and I can't find a link for what can be stacked with what, does anyone have a link?
6 Replies 6
kareem.afifi
1) Yes I say it's def. worth upgrading to the latest IOS. Probably corrected bugs from the older version
2) Yes they both must be running the same IOS/Image
3) Not a 100 percent sure on this. You are probably better off opening a ticket to find out.
Reza Sharifi
Hi Andy,
With 3750s you can mix and match, so you can have a mix of 3750, 3750G and 3750E.
Please refer to this document for adding a switch to your stack:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swstack.html
Reza
Thanks all, what IOS image would you suggest, there are now so many!
15
12.4
12.3
12.2
and within these there are T, Mainline, Special.
I guess I just need the latest IPbase?
IP BASE W/O CRYPTO
c3750-ipbase-mz.122-53.SE.bin
Release Date: 15/Dec/2009
Size: 10358.11 KB  (10606703 bytes)
Minimum Memory: DRAM:128 MB  Flash:16 MB
Or
IP BASE W/O CRYPTO WITH WEB BASED DEV MGR
c3750-ipbase-tar.122-53.SE.tar
Size: 13270.00 KB  (13588480 bytes)
My switch info:
#sh flash
Directory of flash:/
    2  -rwx        1295   Mar 1 1993 00:02:10 +00:00  config.text
    3  -rwx           5   Mar 1 1993 00:02:10 +00:00  private-config.text
    5  drwx         192   Mar 1 1993 00:06:31 +00:00  c3750-ipbase-mz.122-35.SE5
15998976 bytes total (6369280 bytes free)
#dir flash:c3750-ipbase-mz.122-35.SE5
Directory of flash:/c3750-ipbase-mz.122-35.SE5/
    6  -rwx     7175078   Mar 1 1993 00:05:31 +00:00  c3750-ipbase-mz.122-35.SE5.bin
    7  drwx        4224   Mar 1 1993 00:05:54 +00:00  html
  508  -rwx         598   Mar 1 1993 00:06:31 +00:00  info
Andy,
12.2(53) is latest on CCO now. Here is the IP based image name:
Reza
krishnakumarr
Both the switches should be same image.
we can connect 3750 3750G 3750E series also into the same stack
What ever the image is running in the master switch the same image will push into the member switches automatically when u add the switches into the stacks , if it is not happend we need to upgrade the image manually
Attaching stacking doc
regards
krishna kumar
hi
Both are same image one is bin file another one is tar file
pl  refer the ios upgrade in 3750
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml
regards
krishna
