stacking c2975
carl_townshend
hi all, can anyone tell me how you stack the 2975? does it have cascade cables at the back?
also can anyone tell me the most used commands use to stack a switch, and make a chosen one the master.
thanks
Carl
9 Replies 9
glen.grant
The 2975 stacks just like a 3750 with stacking cables in the back . Personally I didn't even know this model existed , thought they only had 2960's . Will have to keep this in mind if we only need a layer 2 switch install .
adamclarkuk_2
Level 9
Level 9
Carl
you keep asking the same questions in different posts ??????
switch stack-member-number priority new-priority-value
hi there, can you give me an example of what values you put in for the about commands please ?
cheers
Hi Carl,
switch 1 priority 15
Translate to: The first switch on the stack has the highest priority (15) and will always be the master.
Default is 1.
do people normally configure there stacks manually? Is there anyway from the LED's on the switch you can find out which is master?
what are the recommended configs for stacking the switches ?
cheers
Hi Carl
If you read my post in your last question regarding stacking, you will see the election process.
There are LED's which tell you the which is master
This link gives more details on the LED's
http://www.cisco.com/en/US/docs/switches/lan/catalyst2975/hardware/installation/guide/HIGOVERV.html#wp1107049
Hi Carl
here is a link for the election
http://www.cisco.com/en/US/docs/switches/lan/catalyst2975/software/release/12.2_46_ex/configuration/guide/swstack.html#wp1234264
They have pretty much ported the 3750 switch stacking code to the 2975 layer 2 switch . Election and priority setting appears to be pretty much the same.
I don't know with other people but I DO. It saves me alot of troubleshooting time when I know the order of the switch from top to bottom.
I also like to power up the stack (for the first time) one at a time so the switches can be stacked according to my order of preference.
