Stacking Cable
hamid22hamo
Community Member
Is there any way to know the length of the current stacking cables form the dashboard and how ?
CMR
Meraki Community All-Star
@hamid22hamo yes, you can click on the port and look at the part number of the SFP module as below:
NDAAFF-M604 is a 100Gb/s QSFP28 stacking cable of 0.5m length
NDAAFF-M601 is a 100Gb/s QSFP28 stacking cable of 1m length
P3007U1M0500-1 is a 40Gb/s QSFP+ stacking cable of 0.5m length
I don't have any other lengths to hand, but hopefully others can add to this list!
If my answer solves your problem please click Accept as Solution so others can benefit from it.
CMR
hamid22hamo
Community Member
Thanks a lot
Which stack cable is appropriate for MS 225-24 p switch stacking??
Need helo
CMR
MA-CBL-40G-1M or MA-CBL-40G-0.5M or MA-CBL-40G-3M
