Stacking Cisco 3750.
apatelli
Is it possible to build a stack between WS-C3750E-24TD-E  and WS-C3750X-24T-E?
rizwanr74
Level 7
Level 7
Hi Apatelli,
Yes, you can, as long as IOS version do not have major version differences.
thanks
Ok, thank you.
Hello.
I just wanted to add, Be aware that 3750x switches with lan base license only stack with other 3750x, if by any change the 3750x is running lan base license it won't stack with other 3750 models.
Regards.
Wilson B.
