Stacking issue
wajid dabir
I am trying to configure stacking between two switches but getting an version mismatch error.
Below are the show version of both switch.
1.
C3750-MB-10IDF-01#show version
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(55)SE7, RELE        ASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 10:16 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE        (fc1)
C3750-MB-10IDF-01 uptime is 7 minutes
System image file is "flash:c3750-ipbasek9-mz.122-55.SE7/c3750-ipbasek9-mz.122-5        5.SE7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24PS (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1235W6FS
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:23:05:92:79:80
Motherboard assembly number     : 73-10217-07
Power supply part number        : 341-0108-03
Motherboard serial number       : FOC1235245L
Power supply serial number      : DCA1234A3FT
Model revision number           : F0
Motherboard revision number     : B0
Model number                    : WS-C3750G-24PS-S
System serial number            : FOC1235W6FS
Top Assembly Part Number        : 800-26855-01
Top Assembly Revision Number    : D0
Version ID                      : V05
CLEI Code Number                : CNMWR00ARC
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24PS     12.2(55)SE7           C3750-IPBASEK9-M
Configuration register is 0xF
2.
Switch#show version
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 12.2(55)SE7, RE
Compiled Mon 28-Jan-13 09:55 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTW
ARE (fc1)
Switch uptime is 6 minutes
System image file is "flash:c3750e-ipbasek9-mz.122-55.SE7/c3750e-ipbasek9-mz.122
-55.SE7.bin"
export@cisco.com.
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
cisco WS-C3750X-48P (PowerPC405) processor (revision A0) with 262144K bytes of m
emory.
Processor board ID FDO1734R18H
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
Base ethernet MAC Address       : C0:67:AF:D2:68:80
Motherboard assembly number     : 73-12553-10
Motherboard serial number       : FDO17340X9Z
Model revision number           : A0
Model number                    : WS-C3750X-48P-L
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO17340HC0
System serial number            : FDO1734R18H
Top Assembly Part Number        : 800-31324-08
Top Assembly Revision Number    : C0
Version ID                      : V05
CLEI Code Number                : COMJZ00ARE
Hardware Board Revision Number  : 0x05
*    1 54    WS-C3750X-48P      12.2(55)SE7           C3750E-IPBASEK9-M
wajid dabir
I know why.
Switch 1 is a plain 3750 but running IP Base feature set.
Switch 2, however, is a 3750X but has LAN Base feature set.
So you will need to upgrade the license of the 3750X to IP Base.
Sent from Cisco Technical Support Nintendo App
Sandeep Choudhary
HI Wajid,
Run this command and check the incompatibilty in configuration of both swicthes:
show platform stack compatibility
please also check this link to resolve:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/switch_stacks.html
Dont forget to arte helpful posts.
wajid dabir
Dear Sandip,
below are the platform detail
------------------ show platform frontend-controller ver 0 ------------------
Software Version   0.43
Serial Number
Part Number
System Type        2
Device Id          1
Device Revision    0
Software Version   0.67
Hardware Version   38
Bootloader Version 14
System Type        5
Device Id          1
Device Revision    0
I know why.
Thanks leo....for your support.
