Stacking or 10GE link between two 3750
aotholland
Dear expert,
We have two 3750 stackable switches in core layer.
What can you recommend?
1. We are planning to stack two 3750 for greater bandwidth to use
2. We could configure 10GE link (by Network module) between these two switches
which solution provides increased bandwidth and redundancy?
Kndrgds.
2 Accepted Solutions
Stacking gives you a 32GBit interconnect, so the bandwidth will be higher.
More important, if you stack your switches, the complete redundancy setup for your network changes. The stack is configured as one logical switch and you can connect channels to both stack members. The stack has one IP that is used as next hop for the adjacent systems and you don't need to deal with a FHRP like HSRP or VRRP.
Both bandwidth and redundancy is better with stacking.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
5 Replies 5
Karsten,
Thanks for quick reply
which is then better for bandwidth?
which is then better for redundancy?
Thank you so much Karsten.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If we're dealing with 10G interfaces on 3750s, this would imply a -E or -X model or the "rare" original 3750G-16TD with the single 10g port (with 1.25:1 oversubscription).  -E and -X models have StackWisePlus 64 Gbps (actually dual 16 Gbps, duplex).  Original 3750 series have StackWise 32 Gbps (actually dual 8 Gbps, duplex).
PS:
Like Karsten, definitely recommend using (both) the stack ports for a dual stack.
