Stacking WS-C3750X-12S-S and WS-C3750X-48T-L
Sunil Gajjar
I have a couple of WS-C3750X-48T-L and a couple of WS-C3750X-12S-S, I want to stack all four of them together into a single stack.
WS-C3750X-12S-S are running c3750e-universalk9-mz.122-58.SE2 whereas WS-C3750X-48T-L are running c3750e-universalk9-mz.122-55.SE3.
I have got a couple of queries as under:
What are the options to achieve putting all these 4 switches into a single stack?
Can the LAN Base switches upgraded to IP Base? If yes, what would be the procedure?
Thanks in advance!
Eugene Khabarov
Level 7
Level 7
The Cisco Catalyst 3750-X Series Switches with LAN  Base feature set can only stack with other Cisco Catalyst 3750-X Series  LAN Base switches. A mixed stack of LAN Base switch with IP Base or IP  Services features set is not supported.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
HTH. Pelase rate if it was helpful.
I have verified it and it is possible by upgrading license on WS-C3750X-48T-L - product number is L-C3750X-48-L-S. It will allow me to upgrade WS-C3750X-48T-L to IP Base so that I can stack them with WS-C3750X-12S-S.
Leo Laohoo
Upgrade the WS-C3750X-48T to the same IOS version as the WS-C3750X-12S.  Make sure that all of the stack members have the same license level.
