How to block Host on VLAN
joseph.steve
Hello Experts
We got 3 VLANS and I have been requested to block some host in each VLAN.
I share this scenario
vlan 2
interface vlan 2
ip address 192.168.1.254 255.255.255.0
vlan 3
interface vlan 3
ip address 192.168.2.254 255.255.255.0
vlan 4
interface vlan 4
ip address 192.168.3.254 255.255.255.0
Host 192.168.1.100
192.168.1.200
192.168.2.100
192.168.2.200  should not be reachable from any vlan
How do I block these host
thank you
Steve
Reza Sharifi
You can try testing something like this:
access-list 50 deny 192.168.2.100
access-list 50 deny 192.168.2.200
access-list 50 permit any
inter vlan 3
ip access-group 50 out
This access-list prevents other vlans to communicate with host 2.100 and 2.200
access-list 60 deny 192.168.1.100
access-list 60 deny 192.168.1.200
access-list 60 permit any
inter vlan 2
This access-list prevents other vlans to communicate with host 1.100 and 1.200
fb_webuser
Level 6
Level 6
could you just disable the port?
Posted by WebUser Appleclean Kan
Eduardo Aliaga
Level 4
Level 4
There are several ways depending on what exactly do you need.
Reza Sharifi showed the use of "router acls". This will block access from other networks.
But if you also need devices from the same vlan 2 (and same network 192.168.1.x) to not access 192.168.1.100 and 192.168.1.200 then you could also use "port acls" on switchports , "vlan maps" (also called vlan acls) or "private vlans".
Please check this link http://www.ciscopress.com/articles/article.asp?p=1181682&seqNum=4
Please rate if it helps. Kind regards
narasimha rao
Hi Joseph Steve,
i think some others said diff options like acl etc,but u have use acl for blocking some host ip,if they are know basic knowledge in networks,they use diff ip and then use it.it's my doubt.
i suggest one option ,witch port is connected to that host,simply go into that perticular port n give shutdown command.or use to mac address blocking method.
