stackwise difference - 3750\3560 vs 3850 vs 9300
vark00001
Hi folks,
I was going through the stackwise feature of different models and found intriguing differences between  the 4 models i know support stacking while going through links below :-
1) 3750 \ 3850 seems to support upto 9 switch in stack but 9300 supports only upto 8
       why ?  my initial thaught was thats due to may be stackpower feature where 9 switch switch may be too much , but then 3850 support stackpower and also till 9 switch in stack.
2) The order and the attributes used to select master seems to differ . Example , whereas 3750\3560 seem to care about feature set like encrypted\non-encrypted images etc , 3850 and 9300 dont care about it. Another factor is in 3750\3560 , the switch up-time seems to be a factor where as in 3850\9300 the term used is shortest start-up time . Whats the differnce ?
Can someone in cisco or otherwise has something that can clear the air on as to what is going on with stackwise feature - sets ? what is cauing ther differences modelwise ?
Links i used are :-
3750\3560 :  https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750e_3560e/software/release/12-2_35_se2/configuration/guide/3750escg/swstack.html#wp1152806
3850 : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3e/ha_stack_manager/configuration_guide…
9300 : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/b_166_stck_mgr_ha_9300_cg/b_166_stck_mgr_ha_9300_cg_chapter_00.html
Varun
0 Replies 0
