Switch Stack
Imran Ahmad
Level 6
Level 6
Hello Experts,
I have newly purchased Cisco Stackable Switches.    but the issue im facing is that, all interfaces in the stack are showing as (shutdown/off).  even i tried to manually turn-on the interfaces using command (no shut),  but still all ints are showing down.
any idea, what could be the source of the issue ?
13 Replies 13
Reza Sharifi
What platform switch you have and what is connected to the ports?
I have switch model 2960x48-LPS-L,     and i have connected computers into the ports.
Post the complete output to the command "sh ip interface brief" and "sh post".
SWITCH#show ip interface brief Interface IP-Address OK? Method Status Protocol Vlan1 unassigned YES NVRAM administratively down down Vlan100 10.160.70.4 YES NVRAM up up FastEthernet0 unassigned YES NVRAM administratively down down GigabitEthernet1/0/1 unassigned YES unset down down GigabitEthernet1/0/2 unassigned YES unset down down GigabitEthernet1/0/3 unassigned YES unset down down GigabitEthernet1/0/4 unassigned YES unset down down GigabitEthernet1/0/5 unassigned YES unset down down GigabitEthernet1/0/6 unassigned YES unset down down GigabitEthernet1/0/7 unassigned YES unset down down GigabitEthernet1/0/8 unassigned YES unset down down GigabitEthernet1/0/9 unassigned YES unset down down GigabitEthernet1/0/10 unassigned YES unset down down GigabitEthernet1/0/11 unassigned YES unset down down GigabitEthernet1/0/12 unassigned YES unset down down GigabitEthernet1/0/13 unassigned YES unset down down GigabitEthernet1/0/14 unassigned YES unset down down GigabitEthernet1/0/15 unassigned YES unset down down GigabitEthernet1/0/16 unassigned YES unset down down GigabitEthernet1/0/17 unassigned YES unset down down GigabitEthernet1/0/18 unassigned YES unset down down GigabitEthernet1/0/19 unassigned YES unset down down GigabitEthernet1/0/20 unassigned YES unset down down GigabitEthernet1/0/21 unassigned YES unset down down GigabitEthernet1/0/22 unassigned YES unset down down GigabitEthernet1/0/23 unassigned YES unset down down GigabitEthernet1/0/24 unassigned YES unset down down GigabitEthernet1/0/25 unassigned YES unset down down GigabitEthernet1/0/26 unassigned YES unset down down GigabitEthernet1/0/27 unassigned YES unset down down GigabitEthernet1/0/28 unassigned YES unset down down GigabitEthernet1/0/29 unassigned YES unset down down GigabitEthernet1/0/30 unassigned YES unset down down GigabitEthernet1/0/31 unassigned YES unset down down GigabitEthernet1/0/32 unassigned YES unset down down GigabitEthernet1/0/33 unassigned YES unset down down GigabitEthernet1/0/34 unassigned YES unset down down GigabitEthernet1/0/35 unassigned YES unset down down GigabitEthernet1/0/36 unassigned YES unset down down GigabitEthernet1/0/37 unassigned YES unset down down GigabitEthernet1/0/38 unassigned YES unset down down GigabitEthernet1/0/39 unassigned YES unset down down GigabitEthernet1/0/40 unassigned YES unset down down GigabitEthernet1/0/41 unassigned YES unset down down GigabitEthernet1/0/42 unassigned YES unset down down GigabitEthernet1/0/43 unassigned YES unset down down GigabitEthernet1/0/44 unassigned YES unset down down GigabitEthernet1/0/45 unassigned YES unset down down GigabitEthernet1/0/46 unassigned YES unset down down GigabitEthernet1/0/47 unassigned YES unset down down GigabitEthernet1/0/48 unassigned YES unset up up GigabitEthernet1/0/49 unassigned YES unset down down GigabitEthernet1/0/50 unassigned YES unset down down GigabitEthernet1/0/51 unassigned YES unset down down GigabitEthernet1/0/52 unassigned YES unset down down GigabitEthernet2/0/1 unassigned YES unset up up GigabitEthernet2/0/2 unassigned YES unset down down GigabitEthernet2/0/3 unassigned YES unset down down GigabitEthernet2/0/4 unassigned YES unset down down GigabitEthernet2/0/5 unassigned YES unset down down GigabitEthernet2/0/6 unassigned YES unset down down GigabitEthernet2/0/7 unassigned YES unset down down GigabitEthernet2/0/8 unassigned YES unset down down GigabitEthernet2/0/9 unassigned YES unset down down GigabitEthernet2/0/10 unassigned YES unset down down GigabitEthernet2/0/11 unassigned YES unset down down GigabitEthernet2/0/12 unassigned YES unset down down GigabitEthernet2/0/13 unassigned YES unset down down GigabitEthernet2/0/14 unassigned YES unset down down GigabitEthernet2/0/15 unassigned YES unset down down GigabitEthernet2/0/16 unassigned YES unset down down GigabitEthernet2/0/17 unassigned YES unset down down GigabitEthernet2/0/18 unassigned YES unset down down GigabitEthernet2/0/19 unassigned YES unset down down GigabitEthernet2/0/20 unassigned YES unset down down GigabitEthernet2/0/21 unassigned YES unset down down GigabitEthernet2/0/22 unassigned YES unset down down GigabitEthernet2/0/23 unassigned YES unset down down GigabitEthernet2/0/24 unassigned YES unset down down GigabitEthernet2/0/25 unassigned YES unset down down GigabitEthernet2/0/26 unassigned YES unset down down GigabitEthernet2/0/27 unassigned YES unset down down GigabitEthernet2/0/28 unassigned YES unset down down GigabitEthernet2/0/29 unassigned YES unset down down GigabitEthernet2/0/30 unassigned YES unset down down GigabitEthernet2/0/31 unassigned YES unset down down GigabitEthernet2/0/32 unassigned YES unset down down GigabitEthernet2/0/33 unassigned YES unset down down GigabitEthernet2/0/34 unassigned YES unset down down GigabitEthernet2/0/35 unassigned YES unset down down GigabitEthernet2/0/36 unassigned YES unset down down GigabitEthernet2/0/37 unassigned YES unset down down GigabitEthernet2/0/38 unassigned YES unset down down GigabitEthernet2/0/39 unassigned YES unset down down GigabitEthernet2/0/40 unassigned YES unset down down GigabitEthernet2/0/41 unassigned YES unset down down GigabitEthernet2/0/42 unassigned YES unset down down GigabitEthernet2/0/43 unassigned YES unset down down GigabitEthernet2/0/44 unassigned YES unset down down GigabitEthernet2/0/45 unassigned YES unset down down GigabitEthernet2/0/46 unassigned YES unset down down GigabitEthernet2/0/47 unassigned YES unset down down GigabitEthernet2/0/48 un...
SWITCH#show post Stored system POST messages: Switch 1 --------- POST: MA BIST : Begin POST: MA BIST : End, Status Passed POST: TCAM BIST : Begin POST: TCAM BIST : End, Status Passed POST: Inline Power Controller Tests : Begin POST: Inline Power Controller Tests : End, Status Passed POST: Thermal, Fan Tests : Begin POST: Thermal, Fan Tests : End, Status Passed POST: PortASIC Stack Port Loopback Tests : Begin POST: PortASIC Stack Port Loopback Tests : End, Status Passed POST: PortASIC Port Loopback Tests : Begin POST: PortASIC Port Loopback Tests : End, Status Passed POST: EMAC Loopback Tests : Begin POST: EMAC Loopback Tests : MAC Loopback Passed POST: EMAC Loopback Tests : PHY Loopback Passed POST: EMAC Loopback Tests : End, Status Passed Switch 2 --------- POST: MA BIST : Begin POST: MA BIST : End, Status Passed POST: TCAM BIST : Begin POST: TCAM BIST : End, Status Passed POST: Inline Power Controller Tests : Begin POST: Inline Power Controller Tests : End, Status Passed POST: Thermal, Fan Tests : Begin POST: Thermal, Fan Tests : End, Status Passed POST: PortASIC Stack Port Loopback Tests : Begin POST: PortASIC Stack Port Loopback Tests : End, Status Passed POST: PortASIC Port Loopback Tests : Begin POST: PortASIC Port Loopback Tests : End, Status Passed POST: EMAC Loopback Tests : Begin POST: EMAC Loopback Tests : MAC Loopback Passed POST: EMAC Loopback Tests : PHY Loopback Passed POST: EMAC Loopback Tests : End, Status Passed FR-
Output shows none of the ports are in shutdown (or administratively down).
But they are all in (unassigned YES unset down down) state. Although i have connected some interfaces with computers but still showing int down ...
Any idea please?
Pick a port that is currently connected and do the following:
1.  Command:  test cable tdr interface <PORT>;
2.  Wait for approximately 5 to 7 seconds;
3.  Command:  show cable tdr interface <PORT>;
4.  Post the complete output to #3.
Hello Leo,
here is the output of the commands you asked:
show cable-diagnostics tdr interface gigabitEthernet 1/0/1
TDR test last run on: July 13 07:35:40
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/1 auto Pair A 0 +/- 10 meters N/A Open
Pair B 0 +/- 10 meters N/A Open
Pair C 0 +/- 10 meters N/A Open
Pair D 0 +/- 10 meters N/A Open
TDR result shows the switch can detect a path of 10 metres and nothing after that. The fault is at the far end.
Dear Leo,
Then what solution you propose ?
@Imran Ahmad wrote:
Dear Leo,
The cable test shows someone isn't doing his/her job properly.
A cable is patched to the switch but at the far end NOTHING is connected to the cable.
Just think about it:  It is claimed that all ports are patched but the switch doesn't show a single port is active.
  • Are the details in the patch sheet correct?
  • Are the patch port terminated properly?
  • Seriously, is the patch cable connected to the computer?  Here's a good hint, look at the computer's ethernet port.  Are the LEDs blinking or not.  If they're not, then duh!, the port isn't connected properly.
Leo Laohoo
What model is the switch?
2960x-LPS-L
