StackWise problem with CPU load and SSH?
leam_hall
Community Member
Anyone seen an issue where doing a "show run" pegs the CPU on a switch that's in StackWise? We have a 6x 3750 stack running 12.2(55)SE and when we do show run the CPU goes to 95% or higher. Often SSH will be at 50-70% of the CPU. A 2x 3750 stack running 12.2(53)SE2 still hits 47% for SSH on the same thing while a lone switch only hits ~13% for SSH.
Thoughts?
Leam
Fabienne Stephanoff
Hello Leam,
Two questions for you:
- can you provide me with the output of "show proc cpu | exc 0.00" while the issue is happening?
- do you see the problem even when you are consoled into the switch or is it specific to when you use SSH/Telnet?
Fabienne
