Stackwise Virtual C9300
prabhatrahul
Frequent Visitor
Frequent Visitor
⁶Hi,
Did mistake by configuring virtual stackwise in C9300 switch . I know it doesnt support VSS. Now both switch keeps on restarting.
Error:
waiting for 120 seconds for other switches to boot
#######Jun 4 15:10:59.082: %PMAN-3-PROCHOLDDOWN: F0/0: The process fed has been helddown (rc 134)
#Jun 4 15:10:59.165: %PMAN-0-
And switch boot automatically!!
I did emergency-install with ios from usb and after completing install it still shows same error.
How can i disable stackwise virtual command from switch: mode.
Please help !!!!
prabhatrahul
Frequent Visitor
Frequent Visitor
HI,
Problem resolved !!!
Contacted TAC and removed STACK Config from Rommon mode.
Thanks for support !!!
5 Replies 5
Mark Elsen
 -Can  you still get into configuration mode between reboots and or then issue : no stackwise-virtual command ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
This is the problem. Switch keeps on rebooting and i cannot go to config mode. Only i can go is switch: mode.
prabhatrahul
Frequent Visitor
Frequent Visitor
HI,
Tx, but share howto here (too).
M.
