Stackwise Virtual SNMP OID
Florian P
I would like to monitor the state of a WS-C3850-48XS configured as a stackwise virtual.
What are the SNMP OIDs involved ? Does anyone have a list of these OIDs and their description ?
The only information I found is the root OID : 1.3.6.1.4.1.9.9.500.1.2
I tried with the OIDs used for "classic "access switches stacks but only a couple of these are working.
5 Replies 5
Mark Malone
This doc explains which mibs you need for stackwise , just search snmp
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-3850-series-switches/q-and-a-c67-738577.pdf
The maybe check the MIB finder for what the docs states
http://mibs.cloudapps.cisco.com/ITDIT/MIBS/servlet/index
Thanks for your help.
I have checked and the information given are valid IOS-XE images. However I am currently using Denali-16.3.5.
Do you know if there have been changes on this topic ?
Best regards,
The snmp mib should be the same whether Denali or standard I would highly doubt they wrote different mibs for each version , the mib is usually for the whole series of ios-xe not just a particular image , I haven't tested it personally but that would be y next step see if it works
I confirm the MIB is the same.
I actually used your files to make the matching between OIB names and values and which values are expected.
ah great glad it woked
