Stackwise virtual
subarayarsooper
Level 3
Level 3
Hi all
How many switches can we stack in front plane stacking method or stackwise virtual. any supporting documents if possible
Thanks in advance
2 Accepted Solutions
Stackwise Virtual is a stack of 2 switches:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-9/configuration_guide/ha/b_169_ha_9400_cg/configuring_cisco_stackwise_virtual.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-9/configuration_guide/ha/b_169_ha_9500_cg/configuring_cisco_stackwise_virtual.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9600/software/release/16-12/configuration_guide/ha/b_1612_ha_9600_cg/configuring_cisco_stackwise_virtual.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
if you read  link I shared, I need to add
there are two tech
stackwise-80/160/480 which is in 9200/9300 here is support UP to 8 SW as M02@rt37  mention
stackwise-virtual (as @Rich R mention) 9500/9600 it support two SW BUT multi supervisor.
so if you looking for High Availability in SW using multi SUP and config Quad-SUP stack wise
NOTE:- the stackwise virtual or 80/160/480 need matching software hardware SW
8 Replies 8
M02@rt37
Hello @subarayarsooper,
The number of switches that can be stacked in a front plane stacking or StackWise Virtual configuration depends on the specific Cisco switch model and software version being used. Generally, Cisco Catalyst switches support different stacking technologies, and the maximum number of switches that can be stacked can vary.
For front plane stacking, also known as StackWise, the number of switches that can be stacked depends on the switch model. For example, some Cisco Catalyst 9300 models support a maximum stack size of 8 switches, while others support up to 9 switches (old 3750).
Best regards
so please tell the maximum number of switches to be stacked using stackwise
virtual in 9400, 9500, 9600 series switches.
you can not stack different platform
multi SW for same Hardware & Software switch
I need to know what is the maximum amount of switches and the official
resources that is mentioned. Please send.
5 FAQs of Cisco Catalyst 9000 Stacking – Router Switch Blog (router-switch.com)
check this link,
within there is link for each Cat9 series datasheet
there are two tech
