Stackwise
tomromo
Community Member
I have two 2960 X switches that were un-stacked from a group of 3.  I'm trying to re-stack the 2 2960x but they will not see each other.  How or is there a way to delete the stack database so I can stack the 2960x switches as new?
7 Replies 7
Collin Clark
On the two switches you want to stack, cable them up, erase the config on each and reload them.
Thanks.  I deleted flash:config.text and vlan.dat  and a boot. still no joy.
Try 'write erase' on each, then reload.
do you mean wr erase on the files directly or where?
From the privileged prompt #.
Switch# write erase
cristoji
As said before simply using write erase and then reload is the simplest method.
Make sure to not save when prompted.
Rob
