Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
If I have a standard 2924 switch and I want to connect it to a 2950 switch, what coding do I need to include since the 2950 does not support ISL trunking? thanks
As far as trunking you are out of luck, you need a newer switch to support the standard dot1q . I believe cisco is slowly phasing out ISL as it is proprietary to cisco only.
