standard and public buffer pool
sarahr202
Level 5
Level 5
hi everbody!
i just want to know when we use " show controllers int e0" command, we get
Rx ring with 16 entries.
My question is does 16 means total number of buffers from both standard public buffer poool and private system buffer pool?
thanks a lot!
Giuseppe Larosa
Hello Sarah,
I may be wrong but I don't think they are the same.
RX ring is more interface related.
see for the system buffers
http://www.cisco.com/en/US/products/hw/modules/ps2643/products_tech_note09186a0080093fc5.shtml#pools
see this example of sh controller ethernet
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s2.html#wp1016433
here the 32 entries are all 1524 bytes each
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sarah,
Hope to help
Giuseppe
thanks a lot Giuseppe!
