standby IP on Subinterface on ASA in the same subnet
Wan_Whisperer
This is an ASA that was configured before my time and I do not understand why They configured a standby ip address in the same subnet.  See below
e0/0.50
Vlan 50
Nameif Server-Farm
security level 100
ip address 192.168.1.1 255.255.255.0 standby 192.168.1.2
I would like to get rid of the standby to free up one more ip.  Can anyone think of why this was put there?
Noob
It looks like the ASA was or is part of an active/standby failover pair, if you check the configuration and it has "failover" commands defined, then it was/is configured for failover.
Is there a secondary ASA appliance?
Do the other interfaces on the ASA have a standby IP address?
Run the command "show failover" to confirm if failover is configured and active. If yes, then you don't want to remove the standby ip address.
