Stateless Autoconfiguration - Default Gateway
fjcardenas-1
Level 3
Level 3
My question is:
Can an IPv6 host learn its default gateway using only stateless autoconfiguration or it needs a stateless DHCP to learn the default gateway?
Thanks.
simontibbitts
Level 7
Level 7
Hello.
Yes - a host can learn its default gateway using stateless autoconfiguration.
For example a Windows machine does it by default. You can use the two DOS commands below to check:
ipv6 if 4
ipv6 rt
Simon
