Static Dhcp Binding
Sanjib Pradhan
Level 2
Level 2
Dear Friend,
I want to bind one client IP address with DHCP manually. Please find below Commands.
1- Router(config)# ip dhcp pool Test
2- Router(dhcp-config)# host 192.168.1.22 255.255.255.0(Client IP)
3-Router(dhcp-config)# client-identifier unique-identifier
If I want to bind another client with the same Pool Is it require to make another pool????????? If it is not require to create another pool, Please mention how to bind with the same pool.
Sanjib
Bilal Nawaz
Hello Sanjib,
You will have to create another pool for dhcp bindings. I have not seen any other way to do this. Having said this you could point DHCP to a file with your bindings in.
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_dhcp/configuration/12-4t/config-dhcp-server.html#GUID-BF29D8F0-2449-42F9-BEFC-76929001FBA5
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Dear Bilal,
Thanks for the support.
If we have 10 client and want to bind 10 IP stastically then I have to create 10 pool..ok
How many number of stastic IP that I can bind?????????????
Sanjib
I am sure that you will be able to do 10 - probably more if you wanted. I'm not sure what limit there is though. I have not come across any limit.
OK....No problem...Thanks Bilal.....:)
