Static entry on ASA
Armegeden
Hello's,
I have a ASA running 7.2.
I'm trying to issue this command:
static (inside,outside) tcp 4.1.14.10 3389 192.168.0.5 3389 netmask 255.255.255.255 0 0
And keep getting this:
ERROR: Static PAT using the interface requires the use of the 'interface' keyword instead of the interface IP address
This is my first time messing with an ASA and I'm just trying to forward any traffic on port 3389 (RDP) to 192.168.0.5.
Help?
Jon Marshall
If 4.1.14.10 is the IP address assigned to the ASA outside interface change your static statement to
static (inside,outside) tcp interface 3389 192.168.0.5 3389 netmask 255.255.255.255
Jon
Jon Marshall
Jon
Gah!
Reading the error message, I tried "outside" instead of the word "interface". Syntax error.
Anyhow, did what you said + added ACL entry and everything working great.
Thanks so much for the fast response!
