08-16-2023 10:52 AM
I'm trying add a static multicast binding to an interface on a 9300 series switch.
ie, I need to force some multicast groups out an interface which does not have IGMP group requests comming in via it. The catalyst guide below says to use the "Device(config)# multicast ip-address 224.1.1.100 vlan 10" formatted style command, however the "multicast" command is not available on the 9300 series.
Any help much appreciated.
08-16-2023 11:35 AM
what is the version of code running on Cat 9K
enable Multicast first before configuring example :
config t
ip multicast-routing
end
then try other commands
08-16-2023 11:59 AM
Hi BB,
its running 17.06.04 CAT9K_IOSXE.
"ip mulitcast-routing" is enabled.
Any other ideas?
