Static NAT does not working on ASR 903
schizoidman8
I have a problem with the static NAT on ASR 903, the commands that I normally use to create NAT on this appliance are not accepted. Please help me to figure out if there is some bug or it is a version issue.
I am running version 16.9.3
13 Replies 13
can you more elaborate, the command is not accept or you enter the command but it don't have any effect?
the router does not accept the commands that normally I use to configure NAT
I have no knowledge that NAT has change on IOS-XE. However, Cisco provide detailed documentation on this matter.
You can refer to this complete guide about NAT in IOS-XE specifically for version 16.9.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-16-9/nat-xe-16-9-book.pdf
 If you find anything different from the way you was used to, please, share with the community.
schizoidman8
Thanks for the info.
I still can't apply the NAT commands on ASR 903, is there any way to enable NAT or should I use another version on the router?
I appreciate your comments.
Regards.
Thanks in advance.
Reza Sharifi
Can't see the entire output you posted. Can you try "ip nat ?" and post it here?
Thanks for sharing. But the problem is not related to IOS version.  You need licensing to run NAT on this router.
IP Security
SL-A901-I
L-SL-A901-I=
Secure Mobile Transport for IPSec/NAPT
https://www.cisco.com/c/en/us/products/collateral/routers/asr-901-series-aggregation-services-routers/data_sheet_c78-686453.html
https://community.cisco.com/t5/routing/asr-901-nat-not-working/td-p/2553642
check this link same issue I think the IOS ver. is make issue here.
schizoidman8
Thanks!
how do I get this license?
I have an ASR 903, is it the same license?
Is the same.
You need to contact a cisco partner.
schizoidman8
Should i open a SR for licencing or just check if we have this service included with the Account Manager?
I dont think it license issue it ios image in router,
Please refer to like i attach.
What IOS image router should I use? The issue still in the router
