static NAT failover
jagannath.cmcltd
Frequent Visitor
Frequent Visitor
Dear Sir,
i have one cisco 4300 router. router interface details: GE 0/0/0 , GE 0/0/1 , GE 0/0/2.
SP1:117.197.102.219 255.255.255.248 172.24.159.241
ISP2:202.142.74.74 255.255.255.248 202.142.74.73
My current configuration with one ISP only (i want STATIC NAT FAIL-OVER OVER TWO DIFFERENT ISP. )
I
Router#
Building configuration...
Current configuration : 1904 bytes
! Last configuration change at 10:38:59 UTC Wed Apr 27 2022
version 16.6
service password-encryption
no service dhcp
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
subscriber templating
license udi pid ISR4331/K9 sn FDO2444109U
diagnostic bootup level minimal
redundancy
mode none
interface Loopback0
ip address 117.197.102.219 255.255.255.248
ip nat inside
interface GigabitEthernet0/0/0
ip address 192.168.14.1 255.255.255.0
ip nat inside
negotiation auto
interface GigabitEthernet0/0/1
ip address 172.24.159.241 255.255.255.252
ip nat outside
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip nat inside source list 99 interface Loopback0 overload
ip nat inside source list 102 interface Loopback0 overload
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 172.24.159.242
ip route 192.168.14.0 255.255.255.0 172.24.159.242
access-list 99 permit 192.168.14.0 0.0.0.255
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
line vty 5 15
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
Router#
Larissa H
Visitor
Hey, Jag
My first thought was to implement 2 individual static routes to each of your ISPs PE router. From what I found that is the basic idea for your situation. Here is what I found:
Source:
https://learningnetwork.cisco.com/s/question/0D53i00000Kt1XYCAZ/nat-failover-with-dual-isp-on-a-router-configuration-example
Well done on being multi-homed btw!
Hope this helps!
larissa
Jag, remember to implement a floating static route to your backup ISP by
adding a higher than 1 administrative distance in the command.
