Static NAT policy (static NAT with ACL) with VRF
cdicesare
I must connect two same network (192.168.1.0/24). These networks are behind a firewall and a Cisco router 2811. The Cisco router 2811 implement VRF.
I would like implement static NAT on the two devices to allow the bidirectionnal communication between the two 192.168.1.0/24 networks.
For this I use the NATed network 1.1.1.0/24 and 2.1.1.0/24.
On the firewall, I implemented a static rule policy nat, which translate the source address 192.168.1.0/24 in address 1.1.1.0/24 WHEN 192.168.1.0/24 PC try to communicate with the subnet 2.1.1.0/24
I would like perform the same with the subnet 2.1.1.0/24. However, I don't find how to perform a static NAT policy, on the VRF galere. I don't want use the global routing table.
Here the ASA rule, that I want to convert on the Cisco router, can you help me
Static (in,out) 2.1.1.0 access-list 100
Access-list 100 permit ip 192.168.10.0 0.0.0.255 1.1.1.0 0.0.0.255 ??
A screenshot of the architecture is in this post.
Thank you in advance for your help.
Cédric
Marwan ALshawi
See the bellow example where you can use ACL for policy nat
You replace the. Interface with nat pool you create
http://www.nil.si/ipcorner/EnterpriseMultiVRF/#chapter6
Hope this help
Thank you marwanshawi for this link !
Are you sure, the NAT pool allow to perform static NAT ? The communication could be bidirectionnal ?
I wish the PC with IP 192.168.1.10 in LAN A talk with the PC 192.168.1.10 in LAN B. When I use the destination 2.1.1.10.
The same with 192.168.168.1.11, 12, 13...
In the option of the NAT in the router I can use also use route-map.
I saw that proxy ARP must be implemented in this post
https://supportforums.cisco.com/thread/2005514
Thank you
Cédric
Its better to check what nat option with vrf your platform support and try it since you are aware about the logic
Network nat can be used or if you have only few hots to be translated you can use static translation per host
