Static/Reserved IP based off of MAC and/or Port # on Switch or Router?
rmorenobb
I have a Cisco 2911 router and a Cisco 2960 switch at a remote location.
I have a user who will work out of this office a few days out of the week and will need to obtain the same IP address everytime the user visits this office.
This office has no file server, no dhcp server.
I have the user's MAC address and for now, the user is getting an IP address that is leased for 30 days.
I'm trying to find the best way to configure either the router or switch or both so that each time this user connects to this office, that user device will always pull the same IP address and of course no other device will use that IP.
I've did some research in creating a small vlan possibly, and assigning it specifically to the port# that the user's desk is at, but not sure if that's the best way or exactly sure how it'll work.
I'm currently studying for my CCNA so this is all new to me and I'm trying to do research and test without obviously causing production issues especially given this is a remote site and I access these devices via putty.  I can however drive to the site if needed for testing, but I'd like to have a good grasp on what method I'll be using that will work before I actually make the trip.
Any advice would be appreciated.
R
cadet alain
for example the IP is 192.168.1.20/24  and mac is 0000.0001.0001
1° get the client-identifier used by the host from the dynamic binding entry:
    show ip dhcp binding | i 192.168.1.20
2° you must remove the dynamic binding on the dhcp server:
-clear ip dhcp binding 192.168.1.20
3° configure the host pool:
   ip dhcp pool host1
   host 192.178.1.20 /24
   client-identifier 01xx.xxxx.xxxx.xx   or hardware-address xxxx.xxxx.xxxx  depending upon result from 1°
Alain
Jonn cos
Level 4
Level 4
You have to configure dhcp on the router and use dhcp bindings so that everytime user with a particular mac address will always get the same IP. Its kinda like dynamic but static IP :-).
cadet alain
   ip dhcp pool host1
Alain
Sorry for the late follow-up, but here's what's happening.
I have this in the config:
ip dhcp pool bloomberghost1-tmirg
   host 192.168.12.26 255.255.255.0
   hardware-address 01f0.def1.9b01.df
ip dhcp pool data
   network 192.168.12.0 255.255.255.0
   default-router 192.168.12.1
   dns-server 192.168.2.50 192.168.1.50
   lease 30
This is what I see on the router:
SF-RTR-01#show ip dhcp binding
Bindings from all pools not associated with VRF:
IP address         Client-ID/             Lease expiration       Type
                   Hardware address/
                   User name
192.168.12.7       01f0.def1.03a7.17       May 08 2013 06:35 PM  Automatic
192.168.12.8       01f0.def1.356d.43       May 08 2013 03:53 PM   Automatic
192.168.12.9       01f0.def1.9b01.df       May 08 2013 09:17 PM   Automatic
192.168.12.26       01f0.def1.9b01.df       Infinite               Manual
SF-RTR-01#
You’ll see the last two entries are the same hardware address, which is the user’s mac.
For some reason, it won't assign that address the .26.  Rather it gave it an address from dhcp.  I'm researching as to why, but thought I'd post my results.
