static route on L3 switch not working
Ibrahim Bhuiyan
Dear,
In my data center I configured static route as like below's scenerio. But I can't ping from PC to Firewall. But in packet tracer this is working but in real life this is not working. what is the problem? can anyone help me?
20 Replies 20
Still some gap of information missing here? can you post Switch 1 config and Switch 3 config to get a good picture of your network.
Still, I see some config issues around. i will look later and get back to you - required some head around.
Quick and Dirty to test. instead of a specific route in switch add another routing  entry ip route 0.0.0.0 0.0.0.0 192.168.100.1  (on both the switches)
still not working post above config and traceroute to destination see where it dropping.
BB
check the real switch configurations. LAN Pc directly connected to access port 1/0/21 of core switch-1.
Core switch to BANet Firewall >>> Ping ok
PC to Firewall gateway(192.168.100.1) or BANet Firewall gateway >>> Ping not found
balaji.bandi
If you have issue in real switch, you need to provide real switch config, not the Lab one. REal world some time different.
Gateway of last resort is not set
This shows some routing issue  for sure, so please post real switch below information to solve the issue :
1. show run ( from real switch)
2. show vlan ( from real switch)
3. show ip interface brief (( from real switch))
BB
Thank you for your helpful comments. I solved the issues.
please share your how this was resolved?
Kind Regards
Paul
Hello
Are you allowing inter area communication between the interfaces?
same-security-traffic permit intra-interface <allows communication in/out of the same interface
same-security-traffic permit inter-interface <allows communication between interfaces with the same interface security level
Kind Regards
Paul
