static route with OSPF into too many routers ??
engcarine
Hello Dear
i have configured 2 different area using OSPF
both area are configured as area 0
first the two areas where not connected together.
but the next step now is to connect the two areas together using static route. ( 2 routers in the first area should talk to 4 routers in the second area)
i did all the configuration found on the net and the ping is working well in one case only: when all static routes are turned on..but this is not the case i want.
i want that whatever happen to these links the ping between the end users still working
can anyone help to solve this issue please..
i have been working with it for 3 months :(
Best regards
carine matar
Reza Sharifi
Way are you connecting 2 area 0s together with static routes?  Just connect them together using OSPF. It will all become one area 0.
