static routes summary
mo shea
Hi...
I am using a class A range with a subnet mask of 24 for our lan. We are connected via ISDN line to another site using 1700 router. I have connected the fastethernet port of the router (10.1.1.1/24)to our core (6506) and gave the ethernet port in the core an IP address in the same vlan (10.1.1.2/24) of the fa of the 1700.
We have 32 vlans, and i want to use static routes, so i am thinking of a way to reduce the number of static route entries on the ISDN routers.
If my vlan range is 10.1.32.x to 10.1.61.x, how can i summarize this?
will 10.1.0.0 work for all vlans or can wildcard masks be used?
Any help is appreciated
Thanx
sstudsdahl
Level 4
Level 4
You can summarize the network 10.2.32.x to 10.1.61.x in many ways. One of which would bee the 10.1.0.0/16 network that you mention. You could also summarize the network as 10.1.32.0/19 which would cover network 10.1.32.x to 10.1.63.x. The static routes for both summarizations would like like:
ip route 10.1.0.0 255.255.0.0
ip route 10.1.32.0 255.255.224.0
Steve
