Static Routes With Next Hop As An Exit Interface Or An IP Address
nezhad
I have always wondered: Why would you want to also specify the link-local address of the next hop in an IPv6 static route if you are already specifying the outgoing interface, which is sufficient by itself?
RyanB
In short, I think it has to do with Neighbor discovery's ICMP redirect messages.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipv6/configuration/15-2mt/ip6-15-2mt-book/ip6-icmp-redir.html
A device must be able to determine the link-local address for each of its neighboring devices in order to ensure that the target address (the final destination) in a redirect message identifies the neighbor device by its link-local address. For static routing, the address of the next-hop device should be specified using the link-local address of the device; for dynamic routing, all IPv6 routing protocols must exchange the link-local addresses of neighboring devices.
Edit:
Mark Holm posted this way back which is along the same lines: https://learningnetwork.cisco.com/thread/83948
Im unsure if this is the only reason though.
But as I mentioned the command without the link local and only the exit interface also works.
Hi Nezhad,
This does not work on an interface that requires neighbor discovery (ND). For IPv4 we have proxy ARP, that allows the router to reply to a ARP query for a destination that is not on the local subnet. There is currently no equivalent for IPv6 (proxy ND).
what doesn't work? specifying only the outgoing interface? but it does. It's supposed to. You don't need to specify the link local address of the next hop necessarily.
